the start of an sr20 with an evo9 turbo
Yea i said it u should know that the best handling performance comes from having all your weight low to the ground. Im sure its not going to make a noticeable difference its just how i wanted to do it and the wastegate stuck out all crazy high. We did consider a top mount it was just not right. Ill powder coat it one day lol Here r some new pics.
www.Fabthis.com
Check out our blog and buy our products
Prestige Worldwide ... Wide..Wide....
www.Fabthis.com
You're talking about moving MAYBE a hundred pounds 5 inches. You're never going to feel that. Saying you went bottom mount for lower cg is absolutely ridiculous...
(O=O/-ROUGH WORLD-\O=O)
Exactly... But regardless, it looks good. Only possible issue is the 1-2, 3-4 pairing.
Nice fab work! Yeah, it's too bad about the pairings, but it'll work just fine. It's not going to work any worse than a single scroll. I expect to see low 300's on that turbo. IIRC, it's like a slightly bigger T28. That outlet is nuts!
not to mention just saying "fuck it" on connecting the correct cylinders, and then trying to sound like a super engineer about a lower cg.
evo ix's are making over 400 on this turbo from a 2.0...your predictions seem low...any reason? im not trying to be a dick or anything, serious question lol
Jebus! A quick search of the internets says you're right. Maybe I'm thinking of older Evo turbos. Actually, the 6.5 TME turbo that everyone want for anti-lag is the one I'm thinking of. DSG went to great pains to use this turbo and only made about 320whp. I didn't know the EVO9 turbos were that much bigger. In that case, it's really going to come down to supporting mods. A set of small cams and you should see mid-high 300's.
