The correct way to build an s14.
Old Mar 31, 2009 | 07:01 AM
  #281 (permalink)
longfellow2's Avatar
FORE:sight
Thanks, with any luck it will be running by the end of the week. Depends on how much time I spend down town at the Grand Prix.
Oil-pump and clutch should be in by friday.
Originally Posted by Epstein
Old Mar 31, 2009 | 07:58 AM
  #282 (permalink)
Nolimitslja's Avatar
Looks great Dan, I would love to see this thing in person, I should be in the Brandon area sometime this week to meet up with Eric. How far are you from him?
Old Mar 31, 2009 | 08:07 AM
  #283 (permalink)
FORE:sight
Pretty far. St. pete is in the opposite direction. lol
Old Mar 31, 2009 | 09:50 AM
  #284 (permalink)
Nevermind then lol. Looks great in the pictures though keep up the amazing work.
Old Apr 10, 2009 | 11:39 AM
  #285 (permalink)
FORE:sight
Motor is finally in the car.
Old Apr 10, 2009 | 12:02 PM
  #286 (permalink)
BABILLARACING's Avatar
nice man coming along really good? those are azenis tires? how they hook ?..........Omar
Old Apr 10, 2009 | 12:10 PM
  #287 (permalink)
FORE:sight
Thanks, its getting pretty close to being a running car again. Just a few more weeks.
Yeah they are RT615's and they suck for launches/drag racing., but grip the road pretty well in corners. Soft compound / stiff sidewalls. You might be able to get them to hook up if you drop the pressure a fair amount but thats not what they are designed for.
Old Apr 12, 2009 | 06:28 AM
  #288 (permalink)
FORE:sight
Wire harness mock up. I still have to put most of it back together and finish routing it but this is to give the general Idea. I'm going for a factory look. The zipties are just temp holding solution. It will look alot more clean when I finish it. The left side is going to be tucked behind and underneath the driveside headlight pan then curve up and run along the upper frame rail and tie back into the factoy location. Luckily I have enough length that it wont hang and I have some harness clips to actually bolt it to the frame so it wont sag and I'll never have to worry about the tire rubbing on it.
The fuse box is getting bolted directly to the back of the headlight pan as well. And will sit exactly where the battery used to. I had thought about relocating the fuse box to inside the car under the dash, but I decided its not worth the effort and I like the ease of access I have to it. So the more simple the better IMO.
Yes I know I have an S13 radiator, but right now I dont really care.
Old Apr 12, 2009 | 07:03 AM
  #289 (permalink)
+Waldo+'s Avatar
Electronicals master ;P
its ok, my rad is for a s13 too lol
good work dan! let me know if you come across another front rad support.. mine is beat up as hell...
Sponsored By Carrabba's
R.I.P. Tim Aldrich
Old Apr 12, 2009 | 07:20 AM
  #290 (permalink)
FORE:sight
My passenger side headlight bracket is fucked up. So eventually I need to get a new one.
You can buy a new core support from nissan. I dont remember how much they are though. Or get an S15 core support from phase2motortrend. IIRC they are the same.
