Synthetic blow off valves
I've seen a site that went into great detail on turbocharging a non-turbo 2.0. He used a bunch of stuff from a turbo eclipse, kept his engine stock though. In the end I believe he could only run 8 or 9 psi safely. Search around, I think I found the link running random searches on a dsm board while in boredom mode.
I was actually on dsmtalk at the time. I don't remember what I was searching for, I was just typing in random things off the top of my head and seeing if anything interesting came up. I'd try variations of "turboing non-turbo" or "turbo NT conversion" or the like, see if you can get anything to come up.
Those fake blow off valves do exist... ask yourself this? Do you want to be "blowing off" only to get torched by a true racer? You would give Eclipses a bad name......
WIth a 2.0 NT block you could get a 6 bolt for cheap around htese parts. I think MitsuBucci was selling his, but I could be wrong.
4G93 1/2 T - down for now
4G69 - daily
4G69 - daily
I want that engine...
but only if its a long block.
anyhow.. a 2.0 NT is perfectly capable of boost. the ONLY Differences are the pistons, cams, and stuff. the reason whats-his-name can only run 8-9 psi safely is cuz of his NT compression ratio and wussy paper thin domes on his stock pistons. and lack of a real knock sensor... and air-flow limiting NT cams.
