Check Engine light after installing bov
Old Mar 26, 2003 | 04:56 AM
Chris LS's Avatar
just blaze...
Default Check Engine light after installing bov
After I installed my hks ssqv the other day, i went and started up my car, and next thing you know i see the "check engine" light come on, does anyone know why this would happen? And what can i do to resolve this problem?
Quote : I'm Slow:
Less hours = less $$. Less repetitive 'ish every day = PRICELESS!
Old Mar 26, 2003 | 07:10 AM
Mr 2's Avatar
New Member
I would just take that piece of shit off your car
Chris LS's Avatar
just blaze...
ANd why would you call it a pos ?
Quote : I'm Slow:
Old Mar 26, 2003 | 11:24 AM
Eikichi's Avatar
did you try to reset your ecu?
Old Mar 26, 2003 | 06:46 PM
Sneakin Deacon's Avatar
PSSHHH x2
its a pos because for the most part if your still running a MAS, your more then likely going to have the problem of stalling after hard acceleration and rough idling, a 1G bov is just fine for the money. venting to atmosphere is bad with our cars, but a vpc would correct the problem because i believe a vpc counts the air at the throttle body and not prior to the turbo like our MAS does. when the hks vents to atmosphere the ecu has already accounted that air into its fueling equation, when that air isnt recirculated back through the intake, it will stall the car.
El Pendejo Loco
2002 Suzuki Hayabusa
1507 "dry" block
Brocks megaphone
Spencercycle 10" swingarm
MPS auto shifter
Hays convertible clutch
Yea, that about sums it up...
Old Mar 27, 2003 | 08:58 PM
PoppaSmurf's Avatar
Chowdah-head
buy a recirculation kit so your car doesn't freak out when the bov dumps, its like $20
Poppa J. Smurf
Old Mar 28, 2003 | 07:06 AM
PiercedJD's Avatar
I'd have to disagree as far as the P.O.S. rating of the hks ssbov.
i ran one for the longest time and the only complaint I had was their flanging method. I hated that fucking slip ring.
the design of the valve itself is flawless. you can get a recirc kit. I would just do that.
I can't imagine it throwing a check engine light.
did you unplug something accidentally while you were putting it in?
check for loose connections.
