99 Eclipse n/a headgasket replacement advice
Old Jan 15, 2003 | 12:03 PM
craig_302's Avatar
boostmonkey
Default 99 Eclipse n/a headgasket replacement advice
I need some advice on the replacement of a headgasket on a 99 n/a eclipse. What kind of prices and parts (besides the obvious) would I need to complete this job? Is there some sort of online guide I can look at to walk me through this process or help me become more informed? I would need to know how to retime the motor and head bolt torque specs and orders as well.
Thanks for any advice.
(note: thankfully this is not my car )
Old Jan 15, 2003 | 06:28 PM
BoostedRS's Avatar
I can freeze time
Click the link on my sig and type 'headgasket', 'head bolts' under seach. That'll answer most of your questions!!!
Olympus Evolt E-510, E-520, E-30 x 2
11-22mm f/2.8-3.5 Zuiko Digital
14-54mm f/2.8-3.5 Zuiko Digital
35-100mm f/2 Zuiko Digital
50-200mm f/2.8-3.5 ED SWD Zuiko Digital
Cybersync wireless trigger
FL-36R, FL-50R, Metz-48, and Vivitar 285HV x 3
Old Jan 16, 2003 | 09:27 AM
craig_302's Avatar
boostmonkey
Thanks alot! Thankfully, it looks like I won't be doing the job...but at least I can give the person a good ballpark price on what needs to be done so that they are not taken advantage of.
Old Jan 16, 2003 | 10:32 AM
b16aRacer's Avatar
Moon Equipped
how the hell do you blow a 99 n/a eclipse's headgasket?
was he trying to be like the movie?
'00 FBP Si
Sebring rule in effect
Old Jan 17, 2003 | 09:35 AM
emodsm's Avatar
red ass
the 420a blows head gaskets like a hooker on sat nights
eric.
Build your car for YOU, not for the fame and glory. Fame and glory fade with time but YOU will be around as long as you live.
Old Jan 20, 2003 | 03:24 AM
Fast420A's Avatar
SRT-4
Yup they blow. Make sure they get the newest MLS gasket and the spray sealant is used as according to Mopar.
If doing the HG and the mileage is anywhere close to 60,000 they should do the timing belt service (including water pump, tensioner and pulleys, and cam seals) as those are also a problem past 60,000.
2004 Flame Red Dodge SRT-4 - 1 or 2 mods
2007 Bright Silver Metallic Dodge Nitro - Stock
