In Need of a Machine shop for decking Block For a MLS
Old Apr 2, 2012 | 05:25 AM
cjackson2802's Avatar
Originally Posted by THE_ONE
HPS Cylinder Head does all the custom head work around these parts, those guys are the real deal and have o-ringed every head I have ever owned.
Ask for Matt 727.505.9068
+1 on HPS. they O ringed my head...I can post some pictures if you want.
Old Apr 3, 2012 | 07:05 AM
Pauls99Gst's Avatar
digg'it
Question guys, I have .40 over wiseco hd's and oem mitsu's only come in 1 size I had someone measure a fel-pro and it was 3.460 over my 3.386 =.074 clearance which is plenty just making sure an mitsu oem is gunna close to the same before i order it, and yeah pics would be pretty cool cjackson if its not to much trouble.
Built 2.0L
ECMLINK
E85
BW S300ETT
& This GS-T hooks
All Built & Tuned by yours truly
In The Garage
- 99 Gst
- 91 Auto Talon
- 95 AWD TSI
& The DD,
a 07, S40 T5
Old Apr 3, 2012 | 09:09 AM
I will post some pictures tonight. i just happend to clean my head up last night...lol
Old Apr 3, 2012 | 10:50 AM
Pauls99Gst's Avatar
digg'it
ok Cool, You happen to know about the gasket? Are you still running an MLS with your setup? or are you running a Composite now?
Built 2.0L
ECMLINK
E85
BW S300ETT
& This GS-T hooks
In The Garage
- 99 Gst
- 91 Auto Talon
- 95 AWD TSI
& The DD,
a 07, S40 T5
Old Apr 3, 2012 | 07:40 PM
OEM Mitsu 4 layer MLS head gasket.
Old Apr 3, 2012 | 10:20 PM
Pauls99Gst's Avatar
digg'it
You go with the copper because your still going with the MLS? Ive seen ss and copper being used with the mitsu MLS it seems like both work just the copper is more forgiving .. Will u be on L19/A1's too? Will definitely be a solid setup.
Built 2.0L
ECMLINK
E85
BW S300ETT
& This GS-T hooks
In The Garage
- 99 Gst
- 91 Auto Talon
- 95 AWD TSI
& The DD,
a 07, S40 T5
Old Apr 4, 2012 | 06:28 AM
  #17 (permalink)
Copper has a better seal because it crushes as you torque the head down where as SS doesnt. and yes I'm using L19's. Motor is definetly going to be solid. If I have any lifting problems I'll probably go to H11's...but I doubt it.
Old Apr 5, 2012 | 09:29 AM
  #18 (permalink)
lancerman's Avatar
I dont recommend copper rings when using MLS gasket.
copper is too soft and just flattens out. . it doesnt really offer any additional seal. after one use the thickness will measure .003-.008 with original .011 height. the idea is to get o-ring to make a groove into the gasket. the only place copper will work well is when using a copper gasket.
YMMV
my favorite quote
Old Apr 5, 2012 | 12:47 PM
  #19 (permalink)
Jerry is correct.
Old Apr 5, 2012 | 01:10 PM
  #20 (permalink)
integra's Avatar
90% grind 10% sleep
Modern Performance in pinellas park does the best work in pinellas I think.
727-546-5653 Cedric
Godwin singer installed someone I know's pistons backwards in their block.
Honda Valve Adjustments 50$
I TUNE KPRO AND S300
I DO NOT WORK FOR FREE
