Is this possible? Question for the Turbo ppl.
I have a 2002 Lancer Bone stock i also have a turbo kit that ive got awhile back my lancer is an automatic. Is it possible to put turbo in an automatic lancer?
Mikey, headstuds and a mls hg at the least. you could run really low boost. Or you can throw an evo 8 head, manifolds, turbo etc. but then you need adjustable cam gears and theres a little fabrication required.
If its anything like the dsms are then yes you can
like all the 4g63 turbo stuff bolts onto the sohc 4g64 stuff from the 90-99s now with the reversed engines like evos then same probably applies
im running 17-19 psi on my all stock 4g64 in my spyder been doing this for a little over a year now
