self boost limit
Old Dec 2, 2002 | 03:22 AM
Jake1234588's Avatar
A.T.F.
Default self boost limit
i have a 96 gst and i wonted to know if thows manual boost controllers are any good i just got on for free and i also wonted to know what is the highits psi i can run on my stock gst,all i have done is i took out the cat
and muffler and just put a tip on it,and i have a stage 3 ACT clutch so what the highits psi i can run with out fucking up the car?
2006 8.0L Up Armored Suburban
2000 Integra LS
Old Dec 2, 2002 | 05:26 AM
Mr 2's Avatar
New Member
nice typing
Old Dec 2, 2002 | 12:10 PM
ben's Avatar
ben
good call mr2
Old Dec 2, 2002 | 12:46 PM
Bob22b's Avatar
lol
you guys are not being nice to the noob
Old Dec 2, 2002 | 04:01 PM
Sneakin Deacon's Avatar
PSSHHH x2
well, safely, i wouldnt recommend more then 15psi on ur little turbo....but before u buy a boost controller buy a boost guage, a/f ,and egt, u want to see if ur spiking or anything to spot a possible problem before it happens...just to be safe
next time u do the clutch go with a ACT 2100/2600
also if u can do this on 2G's (not sure, figure its the same) pull the lower honeycomb out of the MAS and new aircan....simple "free mods" and maybe BCS too, if you know what your doing.
El Pendejo Loco
2002 Suzuki Hayabusa
1507 "dry" block
Brocks megaphone
Spencercycle 10" swingarm
MPS auto shifter
Hays convertible clutch
Yea, that about sums it up...
Old Dec 3, 2002 | 10:13 AM
A.T.F.
hay thanks,and you fucks who were makeing fun of the way i type,when i typed that i was on a lot of pills because i messed my self and my bike up at the stunt show on sunday,so unles you guys can even ride a bike with out falling over then shut the F**k up ok peace
2000 Integra LS
Old Dec 3, 2002 | 12:31 PM
Bob22b's Avatar
What type of bike?
I know this one guy that has a GST and he did the BCS trick, he runs 9s now. Pretty quick now, he's never lost.
Old Dec 3, 2002 | 02:21 PM
PSSHHH x2
uh huh...maybe 9's in the 1/8th...and its not a trick, sometimes it doesnt even work, it just gives you a couple extra psi over stock (Boost Control Solenoid) before i broke i was running 11psi with no boost controller. Anyways, I have been looking around and have not seen the 1G free mods for the 2G's ...only thing you might want to consider doing is cleaning out your IC and taking off/modifying the splash shield if you already havent. and im not sure how much power it will give you, but if you wanted a cheap turbo upgrade, buy a 14b and sell the t-25, shouldnt be too hard to find a 14b for $100 or so.
El Pendejo Loco
1507 "dry" block
Brocks megaphone
MPS auto shifter
Old Dec 22, 2002 | 12:22 AM
slowy's Avatar
13.04@104mph
t25 flows somewhere in the 200's cfm 14b flows in the 400's cfm i believe.
14b would be a goood upgrade for a t25 if u wanted to go inexpensive
