95 motor in a 98 body (420a) help
Old Oct 23, 2011 | 04:39 PM
dsmturbo84's Avatar
Default 95 motor in a 98 body (420a) help
I just got done putting a 95motor rs motor in a 98 rs and some of the sensors are different and I need to know exactly what sensors are different.... I know the cam sensor is different but I know there is more but im not sure what they are... please help
Old Oct 24, 2011 | 01:06 AM
IllegalModz's Avatar
make sure you switch everything around from you old engine. intake with fuel rail. crank position sensor, cam position sensor, coil pack, hopefully you have the old motor to pull parts from. you might also find the water temp sensor is different on the t stat housing and also there is a iat sensor on the back of the intake manifold. its plug also might be different. simple remove everything from the old engine and transfer over and everything will be fine. good luck.
Old Oct 24, 2011 | 02:50 AM
CODE4's Avatar
Tig Welder/Fabricator
Cam, crank, coil, and speed sensor were round pinned in 95, flat pinned for 96-up. As mentioned, use the parts from the original motor or swap pigtails if you have no other option (more labor obviously).
TIG Welder & Fabricator
Old Oct 24, 2011 | 06:49 AM
dsmturbo84's Avatar
I don't have a old motor to pull the sensors off of.....that is why im trying to find out what sensors where different
Old Oct 24, 2011 | 10:35 AM
not having it gonna prove to be a big headache. go fishing at the bone yard
chrish1984
For Sale/WTB Mitsubishi
Nov 26, 2010 10:22 PM
99_Clipse_GS
Sep 22, 2009 05:08 AM
