Gap between manifold and turbo
Old Oct 13, 2011 | 07:48 AM
Romeyo07's Avatar
Default Gap between manifold and turbo
Crap.....
[ATTACH=CONFIG]169340[/ATTACH]
The manifold is flush against the head, leaving a gap between the bottom of the mani and the turbo. I was thinking I could just put flanges to fill the space. What do you guys think?
Old Oct 13, 2011 | 08:02 AM
SuburbanNoize's Avatar
Cold Ass Honky
Why is there a gap? Do the bolts hit the manifold on the other side?
TR DC CREW MEMBER #4
StricklyMT.com
Performance Specialist
727-510-6301
Old Oct 13, 2011 | 08:12 AM
Romeyo07's Avatar
I didn't look, but I feel comfortable saying yes.
Old Oct 13, 2011 | 08:49 AM
IllegalModz's Avatar
everything has clearance or it does not. for instance if its flush on the back then id assume the turbo has clearance between the turbo and engine. now on the front turbo and fans rad etc. again has clearance great? . now the bolts you may have to mod them shorter so u can put nuts on them and get clearance. It has to bolt on flush for sure. use a gasket.. do not put plates or anything like that in. i personally would get the turbo bolted to the mani before install then install the mani/turbo to head... very easy man gl.
Old Oct 13, 2011 | 09:09 AM
Romeyo07's Avatar
That makes sense. I'll cut down the bolts to fit. Wish me luck!
Old Oct 13, 2011 | 12:52 PM
Boost Demon's Avatar
Is that a DSM style manifold and a T3 turbo?
Old Oct 13, 2011 | 01:26 PM
Tom N's Avatar
Non DSM.....DSM guy
its a adapter plate with studs that are too long.
Tom
Old Oct 13, 2011 | 02:17 PM
Gottcha, I see it now.
Old Oct 13, 2011 | 02:29 PM
wishiwasfast's Avatar
They sell shorter studs at ACE... thats what I used for my tubular mani...
Originally Posted by RednekBubba
Just do the normal German torque spec "gudntite"
Originally Posted by 98EclipseTurbo
I have all of the rockers loose on my Intake cam and I believe the timing belt skipped and bent some valves when the harmonic balancer grinded into the valve cover.
Old Oct 14, 2011 | 05:50 AM
cjackson2802's Avatar
cut that dsm flange off and have someone weld the t3 flange on. that'd be the right way to do it..lol
