1g GST runs good with MAF unplugged, dumps massive fuel plugged in
Old Aug 15, 2011 | 04:31 PM
juiced2ndgenteg's Avatar
Default 1g GST runs good with MAF unplugged, dumps massive fuel plugged in
I have tried 3 different MAF and 2 different ecu's, they all do the same thing. I don't think I could have 3 bad maf's but IDK. Looking for insight. ECU wiring was swapped to 91-94 spec.
Old Aug 16, 2011 | 07:19 AM
cjackson2802's Avatar
stock injectors? also check fuel pressure regulator
Old Aug 16, 2011 | 08:38 AM
Stock blue tops, swapped the FPR already. I have swapped The ECT and have checked the power and ground for the MAF. Checked the FMIC and piping for leaks, the intake tube isn't ripped or torn, O2 is good, Good compression 150psi across the board(fresh pistons/rings, 0 miles on her). When the MAF is plugged in the car runs so rich, it fouls the #1 plug, runs on 3 cylinders, and sprays raw gas out the exhaust. This car is driving me nuts, it has been nothing but trouble since I bought it. I'm about to just dump it cheap and concentrate on my DA and s13...
Old Aug 16, 2011 | 12:18 PM
sound like your not getting any spark on cyl 1, try the coil pack?
Old Aug 16, 2011 | 12:21 PM
also the cam sensor on 1g's control the spark and injectors. but those usually dont go bad. check the wiring to it. also, make sure your base timing is set to 5 degrees advanced.
Old Aug 16, 2011 | 12:48 PM
The car runs good with the MAF disconnected. It only runs fucked up with the MAF connected. I thought I made that very clear in my previous posts. I was looking for insight from a dsm pro but, I guess I'm SOL. I just need this thing to run right so I can sell it. I bought it blown up, rebuilt it and now I have found the electrical gremlins DSM's are known for. Thanks anyways.
Old Aug 16, 2011 | 01:00 PM
wishiwasfast's Avatar
Check the ground...
Originally Posted by RednekBubba
Just do the normal German torque spec "gudntite"
Originally Posted by 98EclipseTurbo
I have all of the rockers loose on my Intake cam and I believe the timing belt skipped and bent some valves when the harmonic balancer grinded into the valve cover.
Old Aug 16, 2011 | 01:15 PM
lancerman's Avatar
this sounds like ecu trouble. There is a power cable on the battery that can cause this problem if that cable is left unconnected. It happened to me when i swapped out a battery. car ran very rich like ecu was failing. fried three ecu in row before I found that cable was not connected. luckily the ecus are easily fixed. just look on the back of board to see if there is burned trace. if that is not the issue car would need to be here to be diagnosed further. this type of problem is not easily fixed on paper. dont expect much from people on these forums. it just makes you look bad.
my favorite quote
Old Aug 16, 2011 | 04:56 PM
^thanks, I'll check that. The ecu dosent smell burnt but, at this point anything that I haven't tried I'll check. In the honda and nissan sections there are knowlegable people. Sometimes I am one of them. Thanks.
Old Aug 19, 2011 | 04:13 PM
MAFT and a GM MAF, problem solved. I officially hate dsm's.
riptosredek
Nov 24, 2007 03:41 PM
firstgenrx
Nov 9, 2005 12:21 PM
BABYBOY1982
For Sale/WTB Mitsubishi
8
Aug 18, 2005 09:04 AM
Passion
Jun 13, 2005 01:40 PM
Passion
Jun 3, 2005 12:40 PM
