need help putting in a different wiring harness
Old Aug 6, 2011 | 07:28 PM
dsmturbo84's Avatar
Default need help putting in a different wiring harness
I picked up a 96 rs for a few 100 bucks but it needs a new wiring harness im thinking of going to the junk yard and pulling one out of a eclipse there. Im just wanting to know what am I getting my self in to??
Old Aug 7, 2011 | 01:46 AM
omgosh's Avatar
It is exactly what it sounds like. If youre just talking about an engine harness, it could be done in an hour or so. Unplug, un clip, disconnect ecu and pull it through the firewall.
Main harness is another story..
Old Aug 7, 2011 | 04:18 AM
wishiwasfast's Avatar
The engine harness is easy. Just take your time and dont yank on anything. Start from the ecu and work you way over to the passenger side firewall. Bring a 10mm for the grounds, and an assortment of flat heads.
Originally Posted by RednekBubba
Just do the normal German torque spec "gudntite"
Originally Posted by 98EclipseTurbo
I have all of the rockers loose on my Intake cam and I believe the timing belt skipped and bent some valves when the harmonic balancer grinded into the valve cover.
Old Aug 7, 2011 | 10:30 AM
dsmturbo84's Avatar
How hard is the main harness?
Old Aug 7, 2011 | 10:41 AM
CODE4's Avatar
Tig Welder/Fabricator
Involves removing the driver side fender to access it, and a host of other issues involved as you need to remove significant wiring from under the dash.
TIG Welder & Fabricator
Old Aug 7, 2011 | 10:46 AM
I guess the 4g guys have it 100% easier then...
Sourskittle
Oct 1, 2008 10:47 AM
fearlessaltima
For Sale/WTB Nissan
4
Feb 4, 2007 11:29 AM
00siboy
Sep 1, 2006 05:19 AM
