Need some HELP!!!!!!
Old Jun 20, 2011 | 09:23 AM
kb-kustoms's Avatar
Default Need some HELP!!!!!!
so my water pump was bad so i changed it and put on a new timing belt yesterday, i lined all the timing marks and everything looked good. when i started it, it runs rough, the idle is very bad and i can feel a vibration in the car now, do any of you know what this could be from? Thanks kyle
Old Jun 20, 2011 | 01:42 PM
IllegalModz's Avatar
Something has been over looked that's for sure. If it ran fine before you took it apart and now it does not its something that was done incorrect. Running rough suggests timing marks aren't right or its missing for some reason like crank sensor got hit or something. Check compression, verify a thing or two... Take it back apart inspect all the marks its easy to be a tooth off. Make sure everythings right,, if you have balance shafts check all those marks. Mistakes are made sometimes, odds are its a easy fix you just have to get dirty again.
Old Jun 20, 2011 | 02:14 PM
wishiwasfast's Avatar
Check you timing again. The exhaust cam is probably off one tooth.
Originally Posted by RednekBubba
Just do the normal German torque spec "gudntite"
Originally Posted by 98EclipseTurbo
I have all of the rockers loose on my Intake cam and I believe the timing belt skipped and bent some valves when the harmonic balancer grinded into the valve cover.
Old Jun 20, 2011 | 02:25 PM
kb-kustoms's Avatar
I guess ill take it all apart again
Old Jun 20, 2011 | 04:38 PM
kb-kustoms's Avatar
i triple checked my timing marks they were spot on, this really pisses me off,. i do have balance shaft but when i tear it down i am deleting it.
Old Jun 20, 2011 | 06:25 PM
Boost Demon's Avatar
If I remember right, aren't you suppose to hand crank the motor 3 times and make sure the timing marks are still lined up and nothing is hitting? Hope it works out.
Old Jun 20, 2011 | 09:29 PM
BluRRboSi's Avatar
35.5 psi, stock sleeves
Timing is off. Check plugs.
PUREBRED PERFORMANCE
Fabrication & Tuning Services
813-451-7547 or 813-712-0202
Www.PPETUNED.com <~~ WEBSITE
Curious on honda/acura Ecu Chipping and dyno tuning? Call or visit the website above. Hondata/Neptune/Ectune/Crome Pro. Tuning available for most other systems and platforms as well. DYNOJET
Old Jun 20, 2011 | 09:53 PM
x8psycho8x's Avatar
I say timing...
94 accord vtec - traded
95 eclipse gs - blew up
95 eclipse rs - dd
Originally Posted by SayWhaa?
guess some of the guys shes sleeping with isnt too good with the whole pull out method..
Originally Posted by evlonedb
someone needs to tell her its a vagina,not a clown car!
Old Jun 20, 2011 | 11:06 PM
omgosh's Avatar
Guessing your rear balance shaft is out of phase. Rotate 6 times.
Old Jun 21, 2011 | 12:25 AM
kb-kustoms's Avatar
ya i rotated the motor 6+ times to make sure the oil pump was still in line, maybe the bs is off, if the bs was out of time would that make it mess up? and if i delete it there wont be a belt so is timing for that still a issue?
