stupid fuel line on the fuel pump
Please correct me if I'm wrong, but shouldn't the fitting on the large fuel line that bolts to your fuel pump spin independently of the hose it is attached to so that the whole line doesn't twist as you take it off and put it on?
^lmao
that'd be intresting
Great info guy...lol.
No, actually, it doesnt spin. You have to disconnect the line from under the car in front of the RR wheel...then you will be able to screw the rubber line off the hard line...
Then you bend some metal, pull everything out through the top and find out you have a paul walker fuel pump O.o
an sometimes a little lube too hahah
