Low Oil press
Old Feb 15, 2011 | 05:51 PM
88califox5.0's Avatar
Default Low Oil press
So I just noticed today that my oil press gauge is reading low in fact nothing at idle. Just happed today. Any ideas thoughts?? 95 talon with a 1g swap.
Old Feb 15, 2011 | 08:20 PM
wishiwasfast's Avatar
Is your oil light on? If not then your most likely good. That light comes on when you have less than 5psi.
Originally Posted by RednekBubba
Just do the normal German torque spec "gudntite"
Originally Posted by 98EclipseTurbo
I have all of the rockers loose on my Intake cam and I believe the timing belt skipped and bent some valves when the harmonic balancer grinded into the valve cover.
Old Feb 16, 2011 | 03:55 AM
I have an aftermarket one hook up not the stock one??
Old Feb 16, 2011 | 04:28 AM
cjackson2802's Avatar
every dsm that ive owned, has low oil pressure at idle. i know it seems even worse if your base idle isn't set.
Old Feb 16, 2011 | 04:56 AM
There are two factory sensors. A big one for the gauge, and a small one for the dummy light. I have 25Psi at idle and 75 cruising at 80.
Old Feb 16, 2011 | 05:20 AM
CODE4's Avatar
Tig Welder/Fabricator
Are you asking us or telling us?
Before jumping to conclusions, you need to verify the oil pressure with a known functioning oil pressure gauge hooked up.
TIG Welder & Fabricator
Old Feb 16, 2011 | 07:49 AM
wishiwasfast, who cruises at 80?
Old Feb 22, 2011 | 04:09 PM
eclivic's Avatar
I do, 75-80 everyday all day.
Stangonline
Nov 19, 2006 09:05 AM
CaMaRo 0wNeR
Jun 6, 2006 09:14 PM
lstepnio
Subaru Tech
16
Jul 28, 2005 05:50 PM
Chuck 98 RT/10
Feb 9, 2004 06:18 AM
NT_Hardcore
Mar 7, 2003 11:13 PM
