eclipse gst smoking!! HELP
Old Aug 7, 2010 | 04:06 PM
mcjrotc2010's Avatar
Default eclipse gst smoking!! HELP
i have a 97 eclipse gst. it is smoking, but only when i first take off from a stop and after the car is idle for a bit. wile it is idling it is very light smoke until i tame off again. i did some tests and the coolant is clear, the oil appears to be fine, the coolant tank is still full and clear, the car does go threw some oil, the intercooler pipe that comes from the turbo is coated in oil, there is no shaft play in the turbo, the only thing that i have found that it might be is bad turbo seals, or something in the valve system.
please help.
PM's would be awesome, thanks for the help
AWD FTW!
Old Aug 7, 2010 | 04:24 PM
omgosh's Avatar
Valve stem seals I'd say. Good luck replacing them without taking the head off.
You can do/have a leak down test done...that should point you in the right direction..
Old Aug 7, 2010 | 05:40 PM
wishiwasfast's Avatar
I would lean more toward turbo. Because theres oil in the IC pipe. If it was all in the exhaust valve seals, or something internal.
Old Aug 7, 2010 | 08:13 PM
CODE4's Avatar
Tig Welder/Fabricator
Yep. Burning oil under lengthy idle is indicative of bad valve stem seals.
TIG Welder & Fabricator
Old Aug 7, 2010 | 09:54 PM
thanks for the help.
AWD FTW!
Old Aug 9, 2010 | 01:33 PM
chama-performance's Avatar
my just started smoking alott today and checked the turbo and it had LOTSS of shaft play so i guess its blown..looking for a 16g let me know if someone has one...
Old Aug 14, 2010 | 10:25 AM
MightyMaxGS-T's Avatar
If u want to bring the car to me i can tell you what the problem is. If its the head i can change the valve seals and rebuild the head. If its the turbo i have a guy that can rebuild and/or upgrade urs for a really good price. PM me if u are interested.
PM me for any AC, audio, and wiring work on your vehicle. Including but not limited to car audio, alarms, gauge installs, custom clusters, full troubleshooting, big/dual fuel pump relay kits, battery relocation, factory radio iPod and amplifier integration, custom harnesses, and custom standalone ecu installs and much more! If you need it done, we can do it! Don't be afraid to inquire!
