linkage question
i just got anouther eclipse after kids stole and destoryed my other one but the new one i got will go into 1st gear and if you hold it there you can let the clutch out and some times itll take it other times itll spit it out but once you got it in gear its fine
anyone got any idea!
29 views and no bumps or any additive info... no one has any idea what the deal is do they
could be a few things man, try 3rd, see if it does the same thing. Then try 2nd and see whats up, if its only 1st gear then maybe syncros, if only 1st, 3rd, and 5th shift linkage. If every gear pressure plate. Got to do some testing and shoot us some results before we can help trouble shoot.
When you think you know everything there is to know,thats when you start to learn.
Chip Foose
http://www.teamrip.com/
http://www.importperformanceparts.net/
Chip Foose
First gear doesn't have a synchro. And if the trans isn't spinning then it wouldn't matter anyway. Id try adjusting the cables if you have a 1g...if not I dunno much about transmissions so good luck lol.
its a 97 gst spyder but 1st is having a hard time staying in 3rd get sticky going in sometimes but 5th gear is fine i know the clutch is blown to hell and back and the clutch master cylinder is ripped open and letting the fluid go everywhere but it was still having the issue before the clutch went out so i dont think that it or the pressure plate would have anyhting to do with it hence why i was thinking linkage
but thanx for the feed back keep it coming i need to get those one up and going so i can make it to a dsm picnic up there
^well obviously you should fix those problems before you attempt any more troubleshooting. check the rubber sections of the shift cable for any breakage/cable sticking out. Also make sure the bracket that holds them to the trans is tight.
allright ill check that tomorrow but the cylinder wasnt bad when i got the car i messed it up when i pulled it off to check it lol but im gona have to drop the linkage tomorow and make sure that its not messed up but i was just wondering what everyone was thinking so maybe it could be put out there if i over looked it like an idiot
I doubt this is a linkage issue, sounds like clutch engagement / disengagement or internal trans problems. Go under the hood, disconnect the linkage and put the trans in first by pulling on the levers. If it still spits it out of first its not a linkage issue.
You may know who we are, but we KNOW who you are.
ill have to try that too when its not so damn hot its miserable down here in southern florida but i did get a good laugh it seems that this tends to be a normal problem for eclipses having 1st gear issues lol my buddy and his gf both have issues with there gsts!
I think transmission issues are likely on 11-20 year old cars that in many cases make double the HP from the factory and have people use and abuse the shit out of them daily.
