Help ...how to install?
my brother bought a boost controller from Road race engineering(manual) but its used and didnt come with the papers to show us how to hook it up. Can someone explain to me how to hook it up? I know the engine pretty well i just dont want to mess up on installing it. Thanks
opposite the adjustment bolt/handle there should be a nipple. that nipple should be attached to vaccum/boost source at the intake manifold, or off the turbo outlet elbow.
the nipple perpindicular to that should be attached to the wastegate actuator.
with the adjustment all the way out, it should lower the boost. adjusting it in more will raise the boost.
(EDIT: this is assuming it is like every other ball and spring type MBC available)
