gasket help!!
Old Jun 8, 2010 | 07:43 PM
dsmturbo84's Avatar
Default gasket help!!
i found a good price on a full gasket kit for a 1g (6 bolt) but what i have is a 6 bolt block with a 7 bolt head, so i need to know if it is worth getting....i know the intake is not the same but not sure after that...
Old Jun 10, 2010 | 11:49 AM
pure_kustoms's Avatar
"Non Silba Sed Anthar"
the mounting surface from the block to the head should be the same and the exaust i believe but not sure.
Worst case you will have to trim the ports on the exaust to get the max flow.
hope this helps a little.
Old Jun 10, 2010 | 06:58 PM
omgosh's Avatar
6 bolt turbo gasket kits are different from a 7 bolt. But that doesnt come with a "full kit" anyway...
Intake mani will be different for sure. Id just get a "bottom end" gasket kit for the 6 bolt...then get an upper kit for the 7 bolt. If you need a headgasket I know some places sell a kit with headgasket, valve cover seals, intake mani gasket, valve stem seals, half moon, spark plug seals, and maybe even cam seals and thermostat housing gaskets.
