why the eff wont my injectors shut off?
on
My car tries to keep a 14.7:1 afr on decel. Ive tested the TPS and it in spec...Ive tried adjusting it all sorts of ways with mixed results. I can get it to work ok but it will only shut the injectors off like 1 time out of 50.
Ive tried setting the resistance to .9k ohms... setting the voltage to .5v, .6v .. and setting it so that pins 3 and 4 have continuity when its shut and then no continuity as soon as the throttle is depressed. None of that seems to make it do what its supposed to when the closed throttle switch is activated.
Any ideas anyone? Or do I just have a bad TPS even though it tests as working?
