ebay crank pulley info needed
Old Apr 25, 2010 | 09:12 PM
dsmturbo84's Avatar
Question ebay crank pulley info needed
i know that v8s are so different from a 4g63 but what i see alot is a billet aluminum under drive crank pulley on the v8s, so i want to know why cant you put the same ones on the 4g63 ( OBX BILLET CRANK PULLEY ECLIPSE TALON GST GSX 4G63 SILV : eBay Motors (item 390185127369 end time Apr-26-10 12:50:20 PDT) ) because if the stock one doesn't have fluid, why wouldn't the ebay one be the same as the stock ones???
Old Apr 25, 2010 | 09:18 PM
sl2tuner's Avatar
TR's main honda hater
i dont see any real reason you couldnt.
but im sure someone is gonna tell us
Old Apr 26, 2010 | 04:57 AM
Evil_GST's Avatar
Pure Evil
The stock one is a dampener, it has a rubber ring inside to dampen vibrations. I would stay away from the ebay one.
Old Apr 26, 2010 | 02:47 PM
CODE4's Avatar
Tig Welder/Fabricator
DSMs technically do not run a full harmonic balancer - it is a vibration damper really, the rubber ring provides insulation to accessories as vibrations transmit easily though tensioned belts. For example excessive crank vibrations could accelerate the wear on water pump, steering, and A/C bearings. However both turbo and non-turbo DSMs have ran billet aluminum crank pulleys for years without issues. Even after tear down there is no visible accelerated wear to main bearings due to lack of OEM damper.
Either way, it is your decision. In my experience, I ran a billet AL crank pulley on my stock motor for 100,000 miles with no issues.
TIG Welder & Fabricator
Old Apr 26, 2010 | 05:45 PM
wishiwasfast's Avatar
Don't do it unless you want to possibly destroy your engine...
DSM Forums - View Single Post - Underdrive pulleys [ merged 1/6/07]
Old Apr 26, 2010 | 06:00 PM
got_bst?'s Avatar
Passed you
auch
Old May 2, 2010 | 08:16 AM
IllegalModz's Avatar
OMG well at-least this one will not walk..
Old May 3, 2010 | 10:49 PM
x8psycho8x's Avatar
94 accord vtec - traded
95 eclipse gs - blew up
95 eclipse rs - dd
Originally Posted by SayWhaa?
guess some of the guys shes sleeping with isnt too good with the whole pull out method..
Originally Posted by evlonedb
someone needs to tell her its a vagina,not a clown car!
