Relocating Brackets
Old Jun 12, 2002 | 06:47 PM
1GenEclipse's Avatar
Default Relocating Brackets
Quick question, does anyone know where I can go to get my brackets for my motor mounts relocated?It needs to be cut off and welded on in a different spot of the frame, please help.............And how much do you think something like that would cost?
Old Jun 13, 2002 | 03:11 AM
PiercedJD's Avatar
any welding shop can do it. Not sure what you are doing, so I have no idea how much time would be involved, but figure on 50 bucks an hour.
Old Jun 13, 2002 | 06:49 AM
What I'm trying to do is an engine swap...I have a 1.8 in it now and I want to put a 2.0 turbo in it..In order to complete the swap I have to relocate the motor mount brackets....
Old Jun 13, 2002 | 12:33 PM
PiercedJD's Avatar
putting a 2.0 turbo in a 1.8 equiped 1st gen dsm? why not just get the factory 2.0 motor mounts? hit a junkyard.......
Old Jun 13, 2002 | 08:34 PM
Already hit the junkyard and got the brackets for $150, so tell me do you think I might run in to any other problems with fitting it in the engine bay?
Old Jun 14, 2002 | 03:31 AM
PiercedJD's Avatar
nope, all of these cars were assembled in the same plants, so they are pretty modular, just look at a turbo tosee where the engine mounts bolt on, and bolt away.
Old Jun 14, 2002 | 05:25 AM
Let me ask you this....What else do you think I might have to change or get to make this work?This is wha I got now....
New axcels
Timingbelt
Stork turbo fuel pump
2.0 brackets
New motormounts
IC w/ pipes
Turbo 14b
Downpipe w/ catback exhaust
and now I'm looking for a new waterpump, anything else I might need?
Old Jun 14, 2002 | 06:12 AM
2wdBlazer's Avatar
Vechicle Whore
I would advise againt this swap. It will be alot of work. If your car is in good condition just sell it. Buy a turbo car. Hell, I'll sell you mine. But if you feel you just want to swap it, good luck.
-Kris
Current Projects:
72 2wd Blazer
2013 BMW X5
2008 Chevy TBSS awd
Old Jun 14, 2002 | 06:56 AM
Its a challenge ....Looking forward in doing the swap, its alot of fun.....Can't wait until its done and plus I can say that I didn't buy it like that or it didn't come with turbo had to get it done(swap)....Been talking to a couple of people who had a 1.8 and swaped it to a 2.0 turbo its alot of work but not that much not what you all think, but thankx for the info and support.................
Old Jun 14, 2002 | 01:46 PM
PiercedJD's Avatar
I dunno, you are going to need a lot of parts, I guess I over assumed your knowledge level, and should have realized that you didn't quite know what you were getting yourself into if you didn't know the motor mounts would fit. not trying to be a dick, but you will need a lot of items from a turbo eclipse, the wiring harness, ecu, the dashboard wiring harness, the fuse block which is also where the alternator power connects, the turbo mas, or a 2G mas, 2.0 turbo transmission ( the 1.8 and 2.0 non turbo trannies are different and use different starters, flywheels etc..) axleshafts, you will want to upgrade your brake power assist unit, since the 1.8 had a smaller unit, and most likely the brakes as well. etc etc etc.......
I have worked on a car that was swapped by a very unknowledgeable person, it was a total rattrap....... I had to fix a ton of things just to get it running like a normal stock dsm.
if you are up for a challenge, why not swap the motor into something more worthwhile? maybe a 1st gen rx-7 or a miata, both of which I have considered at one point or another. hell, even a ford festiva or something along the lines of that would be a blast.
mid engine rwd.......... use a fwd tranny, the weight would be ridiculously low, and the power and traction........ very fun ride.... oh..... maybe one of these days
