1g engine question
Old Apr 9, 2010 | 11:24 AM
Krais's Avatar
One less bolt than you
Default 1g engine question
Will a non cam sensor 4g63(1994) Work in a 1993 1g eclipse?
Old Apr 10, 2010 | 08:23 AM
blackFLgst's Avatar
Probably $#%#ing broke.
Will a what? Non cam sensor??? Is the 93 turbo or n/a? If so then yes. I believe the only one that will not work is the 90
REDLEG
13F
2010 Evo X GSR
Mods: 11's
Old Apr 10, 2010 | 10:31 AM
Krais's Avatar
Ah, Will a 1990 6 bolt 4g63-t engine work in my 93 eclipse?
Old Apr 10, 2010 | 11:01 AM
quadzilla's Avatar
It will but you are going to have change a few things on the engine harness,power transistor plug,coil plug,tps plug,swap pins 6 and 14 at ecu,wire in a CAS PLUG this is depending on what you have now. Think that's all.this also based on if your 93 is a turbo.
"Sit right here pimpin,let daddy holla at ya,Now daddy can do this ALL DAY, EVERYDAY,NO PROBLEM". MAKE A PIMP DECISION
Old Apr 10, 2010 | 12:33 PM
Krais's Avatar
My 93 is n/a
Old Apr 10, 2010 | 01:12 PM
blackFLgst's Avatar
Ohhh, yeah you would have a VERY long and time consuming project ahead of you my friend. Find a 91-94 shell and swap it over, replacing everything quadzilla listed on the motor
REDLEG
13F
2010 Evo X GSR
Mods: 11's
Old Apr 10, 2010 | 02:22 PM
Krais's Avatar
Well, would i be able to just swap the ECU and wiring harness to the turbo ones? Would that solve the problems?
