Looking to get into a 4dr 98^ Mirage ...
pro and cons??? ... I will want to slam it, put wheels on it and possibly swap it (but not sure what motors will drop in) or turbo the stock motor. Thoughts pls ...
single cam turbo...lol. It fits but for a swap, An Evo 4g63 will be easier than the eclipse 4g63 cuz the tranny on mirage is in the same side as evos.
^^ single cam turbo mirage from orlando...I made a thread like this a while back..
97 Mitsubishi Eclipse GST
95 Honda Civic ex coupe
95 Eagle Talon ESI
92 Mitsubishi Eclipse GSX
90 Acura Integra LS
94 Honda Civic ex coupe
90 Honda Civic std hatch
90 Acura integra LS
91 Acura Integra GS
98 Acura Integra RS
90 Acura Integra LS
93 Acura Integra RS
91 Acura Integra LS
90 Acura Integra LS
92 Acura Integra Gs-R
95 Eagle Talon ESI
90 Acura Integra LS
90 Acura integra LS
91 Acura Integra GS
98 Acura Integra RS
90 Acura Integra LS
93 Acura Integra RS
91 Acura Integra LS
90 Acura Integra LS
Well, if thats the only swap for the car, then ill just keep the stocker and rebuild it. My plans for the car would be to retain all the power options and a/c ... just a mild build (stock specs, just beef it up with arp's and race bearings and forged internals) not looking to get crazy HP, just around 200-250 wheel on 10ish psi. I would just get the motor built to be reliable not fast. It will be a DD and like I said ... slammed with wheels and clean.
What other motors would you have in mind?? 4g63 is like the best mitsu motor you can get...i doubt that the TT engine will fit but there is an eclipse with that swap in it...if you want more of a challange with a cheaper start up price.. Get a 420a build it up w/ or without boost...and u could do the same w/ the non turbo 4G63 build it N/A & boost it later on...
95 Eagle Talon ESI
90 Acura Integra LS
90 Acura integra LS
91 Acura Integra GS
98 Acura Integra RS
90 Acura Integra LS
93 Acura Integra RS
91 Acura Integra LS
90 Acura Integra LS
95 Eagle Talon ESI
90 Acura Integra LS
90 Acura integra LS
91 Acura Integra GS
98 Acura Integra RS
90 Acura Integra LS
93 Acura Integra RS
91 Acura Integra LS
90 Acura Integra LS
Either way, the motor will be built (mildly) with forged internals and stock specs for reliability, not power. My power goal will be around 200-250 wheel.
Is the stocker a good and easy motor to see those numbers?
I did'nt say not to rebuild the motor. A simple rebuild with new bearings rings and gaskets would essentially be a new motor and should be fine for your goals. but if you want a bullet proof motor to only make 250hp then I guess it's your money.
You would be much better off swapping in a 4g64 from a 3g Eclipse/ 8g Galant. Those motors will reliably hold 300whp all day long from the factory, plus you will get a bit more displacement. Should be your most affordable option.
Stock turbo/Stock Block- 10.80@125.97mph
FP Red/Stock Block- 10.301@132.93mph
http://www.youtube.com/watch?v=k2CqirgpFeM
Hta3582 w-.63Tial/Stock Block- 9.96@139.83mph
http://www.youtube.com/watch?v=rxjaKUnUZNk
Tampa's Quickest Mitsubishi
JUDGE RACING
Join us on Facebook
http://www.facebook.com/#!/pages/Judge-Racing/203463879689026
Sponsored by:
MAPerformance
JUDGE RACING
Join us on Facebook
Sponsored by:
MAPerformance
