need nitrous info
Old Mar 5, 2010 | 12:09 AM
Sippi's Avatar
Mitsu SON!!!
Default need nitrous info
so i've been thinkin of doing a nitrous set up on my 3g and just wondering wat i would need to get started i'm sure a regular kit will come with everything i need but tha info i need is as far as my motor goes what should i do to it to beef it up. I'm competly stupid when it comes to nitrous cuz i've never had a nitrous car so any advice will help oh and specs on the motor are below
Motor : 6G72 (3.0 V6)
Mileage: 105,000 (ish)
motors been a work in progress:
New plugs and wires
New water pump
New Cam shaft seals
New crank shaft seals
New Timing belt
New Timing pulley
New idler
New tensionor(sp?)
New radiator
New Valve cover gaskets
tryin to get the motor back to top shape before the nitrous comes anywhere near the motor like i said anyone that can help its really appreciated
Thanx
Josh
Old Mar 5, 2010 | 05:02 AM
Evil_GST's Avatar
Pure Evil
Well you don't need to much for motor prep if your going to be using a basic kit with a not so big shot. you could start with a fuel pump and replace your fuel filter, as long as enough fuel is getting to the motor you should be fine. other then that just make sure the car is in good working order. I would also recommend you get a bottle heater to go with the nitrous kit, bottle pressure is key.
Old Mar 5, 2010 | 05:42 AM
Sippi's Avatar
Mitsu SON!!!
okay and i'm only going with a 75 shot 100 at the very most. ok fuel pump and filter thanx man. Anything else? lol
Old Mar 5, 2010 | 01:17 PM
bvh's Avatar
bvh
cold plugs,make sure your nitrous kit comes with a wot switch and work your way up with the shot. that's about it!
Old Mar 7, 2010 | 02:35 PM
howeeez's Avatar
howie
Spray Away!
Old Mar 10, 2010 | 04:55 AM
RoadRacer's Avatar
Turn 7 at Sebring
Try the 75 shot with new plugs.
Spray a few times and then check the plugs to make sure it's not running lean.
Patrick -
Old Mar 10, 2010 | 08:11 PM
chillllll's Avatar
11 second club
a wideband wouldn't hurt, and a compression check should be done as well..I have a nitrous kit I don't need anymore...lines, solenoids, bottle, brackets, pills, purge, wot switch, and everything else if your interested. I also have a new in box AEM UEGO wideband
10 sec street truck...
Old Mar 11, 2010 | 12:10 AM
Sippi's Avatar
Mitsu SON!!!
lol thanx chris send me some pics or shared_pm me a price i'm deff interested. I'll have to let drew at darkside take a look at everything to make sure its what i need.
