my car is to low to the ground...
Old Feb 18, 2010 | 11:56 AM
x8psycho8x's Avatar
Default my car is to low to the ground...
so since i need to tires anyways, whats the highest profile tires i could fit on 17in rims on a 2g. now i know it wont make much of a differance but anything will help and since i'm out of a job, buyin bigger rims is out of the question...
any comment would be nice, thanks alot
94 accord vtec - traded
95 eclipse gs - blew up
95 eclipse rs - dd
Originally Posted by SayWhaa?
guess some of the guys shes sleeping with isnt too good with the whole pull out method..
Originally Posted by evlonedb
someone needs to tell her its a vagina,not a clown car!
Old Feb 18, 2010 | 12:08 PM
omgosh's Avatar
well 225/55 16 barely rubs in the back when you hit hard bumps. so figure out how tall that is and then get that height on a 17..maybe a little smaller.
but really it depends on the shock/spring combo, offset, and whether or not you are willing to run spacers/roll your fenders.
Old Feb 18, 2010 | 12:44 PM
x8psycho8x's Avatar
well i think the car has stock shocks but neospeed springs and i don't know how much lower the springs make the car. make any sense? lol
i want diff springs on the car anyways but hard when theres nothin in the wallet
95 eclipse rs - dd
Old Feb 18, 2010 | 01:59 PM
CODE4's Avatar
Tig Welder/Fabricator
Depends on what tire width you are running too. If you have an 8 or 7.5" wide rim then get a 225 or 235 width and 45 sidewall.
I am running 215/55ZR16 on a 16x7 rim. Lowered on Eibach ProKits and do not have much problem - but it is usually only me in the front and my emergency tools in the hatch.
use the following to compare current tire with possible solutions.
http://www.1010tires.com/tiresizecalculator.asp
http://www.miata.net/garage/tirecalc.html
http://www.discounttiredirect.com/di...foTireMath.jsp
Just google man. These are common tools.
TIG Welder & Fabricator
Old Feb 18, 2010 | 04:29 PM
x8psycho8x's Avatar
well as of right now i'm running 205/40/17. i'm only about 90% sure about the 205 tho lol. been worried about gettin it running and not tires, but now that its running i need tires lol
95 eclipse rs - dd
Old Feb 18, 2010 | 08:21 PM
omgosh's Avatar
you should try 225/50/16 on those...speedo is pretty damn close and you get a smaller sidewall/wider tire..
Old Mar 7, 2010 | 04:30 PM
got_bst?'s Avatar
Passed you
i can give you my stocks in a trade and you can get some cash 2
