255lph fuel pump
Old May 20, 2002 | 05:55 PM
aimisgoop's Avatar
Cracka-Faced Cracka!
i have a 90 laser turbo. anyone knwo where i can get a NEW 255lph for a good price? also is anyone in here willing to help install or know a good install place for cheap?
AIM: AIMisGOOP
Originally Posted by moldyhands
in the immortal words of the very wise Kid Rock, "3 foot tall with a 10 foot dick"
though for me, you'd have to change it to 10 inches, and you'd have to change inches to millimeters, and you'd have to change 10 to 5 and you'd have to change dick to poor excuse for one.
Old May 20, 2002 | 06:45 PM
MitsuBucci's Avatar
Olde Skool DSM'r
http://www.autoperformanceengineering.com/
Thats where you get it. Instal is not that hard. Search www.dsm.org . Look through the vfaq.com section. You will find instructions there.
Joe B.
Wrenches, Races & Rides
Old May 20, 2002 | 06:51 PM
AWDTSi's Avatar
You can get them even cheaper here $95 shipped with install kit and filter. Cheapest price you will ever find.
G-Force
Phone: 818-501-2097
Old May 20, 2002 | 07:23 PM
highoctane's Avatar
The pump swap isnt bad at all hardest part is getting the fuel line loose get some Blaster and let it soak on the fittings over night they can be a major PITA to loosen!!
If the car is FWD make sure to do it on an empty tank or be prepared to drain the fuel in the tank. The fuel pump bracket on the FWDs is held in place by a bolt through the bottom of the fuel tank doubles as a drain plug for the fuel tank you have to take the bolt out to remove the fuel pump assembly you also need to loosen the rear holding straps for the fuel tank to let it drop just enough to get the fuel pump assembly out.
All in all not bad to change out the higher you can get the rear the easier it will be car lift is very desirable.
Brad
1997 Eclipse Spyder GST 14.1 @ 100 MPH
1991 Eagle Talon AWD (HOW) 11.574 @ 115.29 MPH
1990 Plymouth Laser RS-T (Organ Donor) 13.19 @ 110 MPH
Old May 20, 2002 | 08:16 PM
aimisgoop's Avatar
i goto ptec im in the autmotive class so i have access to over 15 lifts...and all tools i have never worked on anything like that at all really is it somehtin i could learn by just doing it...like will i see what i have to do as i go along
AIM: AIMisGOOP
Old May 20, 2002 | 08:19 PM
PiercedJD's Avatar
its pretty straightforward once you locate where youre working.... som screws some REALLY TIGHT flare fittings...... rest is a piece of cake.
Old May 21, 2002 | 01:43 PM
aimisgoop's Avatar
i dont know how to do that tho...im sure someone in my class can do it so i might just do that...
AIM: AIMisGOOP
Old May 21, 2002 | 02:18 PM
PiercedJD's Avatar
its really simple man.... REALLY simple....... heck I can tell you what tools youll need. phillips head screwdriver 14mm flare wrench and a 19mm flare wrench and a pair of vise grips (just in case the flare wrench starts slipping). a pair of wire cutters and a couple of zip ties. a small piece of rubber would be nice also.
theres a cover plate you have to remove then unplug the pump. remove the fuel feed line and unscrew the screws holding the pump mounting assembly in the tank.
when you mount the new pump to the mounting bracket put a small piece of rubber between the pump and the back of the bracket. it quiets it down a little and use the zippy tie to hold it in place on the bracket.
any further questions can be answered by the vfaq on it.
for an awd http://www.vfaq.com/mods/pump-WB-1GAWD2-print.html
for a fwd http://www.geocities.com/MotorCity/S.../5051/pump.htm
only way to get to know your car is to put in the time wrenching on it yourself. I dont let anyone work on my car.
Old May 21, 2002 | 09:02 PM
aimisgoop's Avatar
ooh that doesnt seem that hard but i dont think i will be installing it any time soon seeing as how i had to put my car in the shop today for a new shift cable...($290) so that basically used the money i was gonna use to get the 255lph and the boost controller....o-well i guess i have to get a job...=(
AIM: AIMisGOOP
Old May 22, 2002 | 01:52 PM
PiercedJD's Avatar
new shift cable? why? why not get a used shift cable? heck I have a set of them sitting here.
