what sensor is this... 4g63
Old Jan 28, 2010 | 09:50 AM
mikiemike75's Avatar
mikiemike75
Default what sensor is this... 4g63
so i was going to reuse this sensor from my old swap well the damn plug got smashed somewhere along the way... i believe its a water temp sensor but not 100% sure... im running an after market in hose sensor so im not to worried about it if thats what it is... also does anyone know the thread pitch on these motors ive used standard and metric and can find a set screw to plug it with... this is a pic of where the sensor screws into the block at... back under the intake in the middel...
Built By:Mike Carpenter @ Overdose Performance in Ocala,Fl...
Tuned By: Tony Gannon @ Hp Performance
hp~5!! trq-4!!
doing work!!!!!!
Old Jan 28, 2010 | 09:54 AM
Evil_GST's Avatar
Pure Evil
Knock sensor, your going to need that.
Old Jan 28, 2010 | 02:24 PM
mikiemike75
well fuckit fuck fuck... thought it was water... damn... anyone have one...
hp~5!! trq-4!!
doing work!!!!!!
Old Jan 28, 2010 | 05:02 PM
bvh's Avatar
bvh
3 post in this thread and iv laughed twice!
Old Jan 28, 2010 | 05:45 PM
toyotiny's Avatar
your water temp sensors are going to be up on your thermostat housing. make shure you dont wack the wrong one thow! one's just for your guage the other is for your ecu. and just in case,( you need the one for your ecu!)
THE WING MAN NEVER LETS YOU DOWN!
Old Jan 28, 2010 | 06:43 PM
omgosh's Avatar
^the plastic plug is for the ECU I believe, and the spade connector is for the gauges..
Old Jan 28, 2010 | 06:56 PM
rairai's Avatar
I agree with it being the knock sensor. Ill look and see if i have another one on my other block! If i do ill give you a shared_pm. Its for a 1g not sure which you need.
I love my Dsm.
Old Jan 28, 2010 | 10:03 PM
BOX SENTRA's Avatar
OG MUDBONE 240sx
^ it says he has a 95, so he would need a 2g. im not sure off the top of my head if the 1g sensors work.
-Dane
98 240 w/ bolt-ons
Srqspeed.com
Old Jan 28, 2010 | 10:09 PM
mikiemike75
thanks guys yea i thought for somereason it may have been water... looked like a water temp sensor... (first time with a 4g build) anywho i also dont know if the 1g plug will work believe they are different just from cross referincing codes through a buddy at tires plus... anyhow anyone got one let me know will need it fairly soon...
hp~5!! trq-4!!
doing work!!!!!!
Old Jan 28, 2010 | 10:27 PM
BOX SENTRA's Avatar
OG MUDBONE 240sx
it will screw into the block, but the 2g ecu is going to be calibrated for the 2g knock sensor, i think the 1g knock sensor is really sensitive, so your car will act up.
-Dane
98 240 w/ bolt-ons
Srqspeed.com
