Smoke from turbo area
Old Jan 2, 2010 | 06:22 PM
wishiwasfast's Avatar
Default Smoke from turbo area
I've had a smoking issue in the turbo area for while now. I kept thinking it was the turbo feed line. I just replaced it today with a ss line, I cleaned all the oil off everything before I drove it home, the car had no balls at all. It would spool up like normal but wouldn't go anywhere. When I parked I checked under the hood and the turbo area was smoking again, but no leaks on the feed line at all.
If a turbo has no side to side play, but a mm or 2 in and out play can it be bad?
Old Jan 2, 2010 | 06:25 PM
Ares's Avatar
you my friend are el boned as they say lol i would look into a new turbo my saab did something sim and when i brought it to the dealer they told me it was smoked
there are those of us who choose to fight and those of us who choose to stand on the fence and watch not wanting to get involved. but we all search for a small measure of inner peace but few of us ever find it
Old Jan 2, 2010 | 08:17 PM
BoostedTalon00's Avatar
DSMPowered
+1 and also check for exhaust leaks. But if you're smoking and its not the turbo, could be other issues like rings or seals or a leak somewhere in the general area.
GOT LOVE FOR THEM DSM'S
Old Jan 3, 2010 | 03:34 AM
When I installed the feed line the back of the exhaust housing had a ring on it that looked 'wet' or darker than the rest of the housing.
Old Jan 4, 2010 | 11:19 AM
dsm_gst's Avatar
When I blew my 60trim it had absolutely no up/down shaft play, but had about an eighth of an inch in/out play .lol I had oil practically spraying out of my exhaust, but had no oil on or around the hot side or o2housing. It was all still still sealed in the exhaust. Only thing I could say is unbolt the o2housing and serperate it just enough to look on the inside of it and the turbine housing for oil. You would know it if it was blown tho.... White wall of smoke behind you and/or the sound of marbles in a blender... Lol
Originally Posted by LSrex
what do you tell a bitch with 2 black eyes....
Originally Posted by markzeronine
Nothing, you told her twice.
Old Jan 4, 2010 | 05:14 PM
Ok, I have no smoke out the back. Or not enough to see. That makes me feel a little better.
Old Jan 4, 2010 | 06:04 PM
pure_kustoms's Avatar
"Non Silba Sed Anthar"
in and out play is worse then side to side play. check you lines,.
Old Jan 5, 2010 | 08:34 AM
Tom N's Avatar
Non DSM.....DSM guy
Correct. Its not uncommon for a turbo to have a little side to side play. Any in and out is bad. Sounds like the turbo has bad seals and is leaking oil into the exhaust housing as is going to come apart soon.
Tom
Old Jan 5, 2010 | 09:06 AM
mikiemike75's Avatar
mikiemike75
it sounds like could be a toasted turbo... but could be a number of things... possiably a bad flange gasket, rings, bearings, check compression... but i dont see how just changing the feed like has caused you an issue with the motor so im thinking jus thte turbos bad... i got a 14b if your interested internaly gated at 12lbs... for cheap just throw and offer...
Built By:Mike Carpenter @ Overdose Performance in Ocala,Fl...
Tuned By: Tony Gannon @ Hp Performance
hp~5!! trq-4!!
doing work!!!!!!
Old Jan 6, 2010 | 04:44 PM
markymark1082's Avatar
My guess is seals.
