idle problem when warm help
on
hey my 99 gst is giving me idle trouble when its warm fells like it wants to turn off and sometimes it does
it there any way to test the idle air control valve
or any other problems it can be
Check timing again just to make sure, then check the position of the tps with a volt meter if you know how to do that, then I would try replacing the IACV. I'm not sure if there is a way to test them. I have had one in the past give me a problem, but it was dirty, maybe try taking it off and cleaning it up w carb cleaner. Post updates
Also, could be your Idler pulley's bearings are about to go.
GOT LOVE FOR THEM DSM'S
on
just cleaned throttle body still doing it
one of my sparkplug wires is swollen but it still sparks idk if that will be it
and now i am going to replace the iacv
