valve steam seals???
You can. You will need to get a threaded fitting that will screw into your spark plug opening and use an air compressor w a regulator and hose to the fitting to get the cylinders under air pressure to hold the valve from falling into the cylinder. Depending on the motor you have, if its a 4G63, you will need a custom valve spring compressor and not your ordinary one from an auto parts place. I would recommend thinking about getting your hands on that first.
GOT LOVE FOR THEM DSM'S
TR 5th Gen Civic CREW Member #14
T & C Racing
What VP Race fuel's should we carry?
FT Crew Mascot lol
Gotta love my hater fan club. I love the fact people worry about me 24/7 Ill never be forgotten. I love you guys.....
T & C Racing
FT Crew Mascot lol
Look, you need to find a valve spring compressor that will work for the 4G63 head first. There is one that will bolt to the head and you can turn a compressor that has an opening for the keepers. Talk to TR shop "IllegalModz" Seth there has a great valve spring compressor for that head. Get a comp tester and plug it into an air hose and a compressor as stated. Its not that simple, but its not very hard at all. If you are not confident, you WILL NEED to have someone of experience do the job.
Yeah if you drop it into the cylinder it will be alot more work then.
T & C Racing
FT Crew Mascot lol
T & C Racing
FT Crew Mascot lol
will I'm having a motor built but i don't want to use that head if all this head is a set of valve seals..
will let me tell you what is going on I'm having smoke come out of my tail pipe and from what i have found out it is the valve seals or the turbo is going bad and with it being a stock turbo and my car is a 96 so it might be the stock turbo for this car but since the valve seals are cheap i would like to do that as will..
BoostedTalon00 i for got to ask if you have a number for "IllegalModz" because i can't find them in the shop spot
AutoModz
Ask for Seth
I would just have someone do it for you. No offense and don't take this wrong but you seem like you haven't done this job before and I would highly recommend someone else do it if the head is on the block. That method is definitely harder than it would be with just the head.
Ask for Seth
