Question about oil squirters
Do they just unbolt and bolt news in? Tried searching online, repair manual and through mitsu catalogs to see if you can buy just the squirters but can't find anything.
They are 2pieces. The hollowed out bolt that has a spring and ball (check-valve) inside slides into the banjo style side of the squirter. You can buy the check-valves from the dealer and clean the squirter real good with carb clearer and a thin piece of safety wire.
When you unbolt them, they will just fall into two pieces.
Hope this helps.
Hope this helps.
