420a header help
Old Nov 18, 2009 | 12:14 PM
jamison's Avatar
Default 420a header help
when i bought my 95 rs, it came with some headers in the back and dude that sold it too me said that all it needed was a flange welded onto it. I have the motor completely out of my car now and i have compared the headers to the stock manifold. The headers are longer and if a flange is welded on then it wont line up correctly with the down pipe. From the small amount of research i have done i think i have a cup ball joint or something like that, i just dont see how to connect it to the down pipe, any suggestion?
Old Nov 18, 2009 | 07:23 PM
bronxsoldier813's Avatar
Pics? do you have a stock down pipe you might have to get one welded
Old Nov 19, 2009 | 01:59 PM
jamison's Avatar
as you can see the header is significantly longer than the stock manifold
here is the end of the header vs the end of the DP, i dont see how it to connect them
there is alot of shit attached to the DP and most of the bolts attaching everything are ridiculously rusted
Old Nov 19, 2009 | 03:12 PM
yea you need to find a welder.... from your pictures it looks like you would have to cut your downpipe a little and the best way to do it would be buy a flange to weld on the header going to down pipe so you can take it out easier in the future...re use the down pipe flange just drop it a coulple inches so headers will fit....or much easier would be to get it welded as one whole piece and like i said it will be more difficult to take out in future.
Old Nov 19, 2009 | 03:13 PM
make sure flanges are in the same position or you will never get bolts through them
Old Nov 19, 2009 | 09:49 PM
jamison's Avatar
do you know of somewhere i can just get a DP that is a proper fit? that seems like it would be much easier
Old Nov 19, 2009 | 09:57 PM
jamison's Avatar
just found same header+appropriate DP for under 50 bucks, plus its silver which will look better with my intake, good shit, i shoulda just checked ebay first
Old Nov 20, 2009 | 10:29 PM
99_Clipse_GS's Avatar
I picked up a Greddy header from the junkyard and I had a downpipe welded for it at Rainbow Muffler. Been on nearly 6 months and not one problem with it. Very clean, professional welds too.
whats this
Old Nov 21, 2009 | 12:09 PM
jamison's Avatar
how much did they charge for the weld work? my budget isnt what i wish it was
Old Nov 21, 2009 | 12:46 PM
Go to Auto Air Muffler & Brake City, Tampa, FL : Reviews and maps - Yahoo! Local.... They are reasonable if your on a budget i got them to make me a cat eliminator charged me about $40
