2g Not Cranking!!!
Old Oct 25, 2009 | 12:28 PM
wishiwasfast's Avatar
Default 2g Not Cranking!!!
So my 2g was starting, running fine. I changed the trans fluid, removed all the speakers, looped the egr lines, and removed cut wires in the stereo area. I turn the key to on, everything seems fine. But when I take the e-brake off, the brake light stays on, just dim. There is no click from the starter, and I checked the starter wire (black w/yellow stripe). I also attempted to start the car via jumper cables, nogo and popping the clutch, nogo.
Anyone have any ideas??
Old Oct 25, 2009 | 07:02 PM
omgosh's Avatar
To test the starter you can take a wire and run it from a 12v source (battery) and touch it to the terminal on the starter solenoid. The starter should turn if it has power/ground. If that works then your starter circuit is probably open/shorted.
2g starter circuit parts blow ass. I used to have intermittent no-crank problems, replaced the wiring, starter switch, etc. Got tired of it breaking so I just hooked it up to a push start button...
Old Oct 25, 2009 | 07:17 PM
Ok, the damn starter is new, well refrub. I have the full electric manual so I'm taking tomorrow off to fix this damn thing...Damn DSM's....
Old Oct 25, 2009 | 07:26 PM
omgosh's Avatar
Did you check the main alternator fuse? Big 60 amp iirc.
Old Oct 25, 2009 | 10:15 PM
Yea, its the 100amp one. All the fuses under the hood are fine.
Old Oct 27, 2009 | 05:15 AM
BoostedTalon00's Avatar
DSMPowered
Check the clutch pedal release plug under the dash. Maybe that someone messed w that? Just a suggestion
GOT LOVE FOR THEM DSM'S
Old Oct 27, 2009 | 03:32 PM
I figured it out on my lunch break... The douche that owned the car before me seriously destroyed the wiring. In the center console there are two relays that are bolted down to the floor in front of the ecu. The one on the left is the door lock 1 relay and the one on the right is one of 2 starter relays. Well the door lock one was moved to the right where the starter relay was and unplugged the starter relay completely, no sign of it anywhere. They jumped the plug with a piece of wire to bypass it! So I removed the wire on Sunday thinking that is was for the none working power locks. Replaced the wire in the plug (bottom vertical slots) and it started right up with no issues. I'll pick one up this weekend at the junkyard.
Old Oct 27, 2009 | 04:51 PM
DSMPowered
Glad to hear problem is solved! Good luck bro!
Old Oct 27, 2009 | 05:12 PM
Thanks!! Now I have a vacuum leak or something... It will idle at 1100-1000 with 15-14 in/hg, then drop to 500 with 10in/hg... No CEL
