EGR Hose Looping?
So I removed all of the excess vacuum lines, as per Drew and Taboo SS. Now Drew said to loop the EGR lines to avoid the CEL. How do you loop them? I stared at all the EGR crap and came up with anything.
The EGR valve (under the intake manifold) has two fittings coming off it, just take a vacuum hose and connect it to one then to the other one (looping). This helps to delete vacuum without having to block off the EGR valve or you can just buy an EGR block off plate and install that. Looping is just a quick and costfree fix.
GOT LOVE FOR THEM DSM'S
