not building boost
Old Oct 10, 2009 | 09:28 AM
25 to LIFE's Avatar
Default not building boost
I usually run 20 pounds of boost out of the 14b on the 92 Talon with no problems. I just changed out the timing belt and water pump and stiffened up the motor mounts and took it out and it will now only build up 10 pounds of boost. I have a manual boost controler and I have adjusted it but still can only build up 10 pounds. I have checked for exhaust leaks but none are to be found. All my timing marks are to spec. Any ideas?
Old Oct 10, 2009 | 10:16 AM
Needfstwheelz's Avatar
^ HIGH...My Name Is
intake not hooked up all the way...vac lines..?? check ur work something is probly disconnected...unless its ur wastegate.
97 Mitsubishi Eclipse GST
95 Honda Civic ex coupe
95 Eagle Talon ESI
92 Mitsubishi Eclipse GSX
90 Acura Integra LS
94 Honda Civic ex coupe
90 Honda Civic std hatch
90 Acura integra LS
91 Acura Integra GS
98 Acura Integra RS
90 Acura Integra LS
93 Acura Integra RS
91 Acura Integra LS
90 Acura Integra LS
92 Acura Integra Gs-R
Old Oct 10, 2009 | 11:20 AM
BoostedTalon00's Avatar
DSMPowered
^+1 all else fails...check for slight boost leaks. Could also be ur exhaust bearings....lol...im kiddin
GOT LOVE FOR THEM DSM'S
Old Oct 10, 2009 | 12:01 PM
Rich's Avatar
Old School.
Boost leak.
You may know who we are, but we KNOW who you are.
Old Oct 10, 2009 | 12:20 PM
DSMPowered
^ didn't I just say that???
Old Oct 10, 2009 | 12:35 PM
^ HIGH...My Name Is
boost leak would throw off the idle slightly...u wud...or shud feel the difference..
If u go to str8 to 10 psi with barely any effort= boostleak
If the boost is building normal and doesnt go past 10= a line is more than likely not connected...
or idk if u took your whole setup apart to do timing belt but maybe the turbo wasnt bolted back on completly...check for loose turbo to mani bolts
95 Eagle Talon ESI
90 Acura Integra LS
90 Acura integra LS
91 Acura Integra GS
98 Acura Integra RS
90 Acura Integra LS
93 Acura Integra RS
91 Acura Integra LS
90 Acura Integra LS
Old Oct 10, 2009 | 12:41 PM
DSMPowered
LOL, I have NEVERRRR had to take the turbo off to do a timing job...scratch that off the checklist cuz that isn't the issue.. If anything check timing, if its off even the slightest bit, it will throw everything off including boost pressure...def check timing...not just with a light, look at tdc versus cam timing marks. I bet that's the case, and if not, def a vac or boostleak..
