Eagle Rods Ftl
saw in person today. I think the engine fared same fate as my blue car. Misfires with e-85 can lead to pre-ignition. This would have killed a crower rod as well. You can see the cracked pin as well. takes hellava force to do that.
wasted spark fires at BDC as well as TDC. if you have ignitable mixture left over from misfires. you can get combustion at BDC. the rod is at poor angle to handle the load and is simply not designed to handle that kind of compressive force.
1993 Plymouth Laser - Eagle/Ross 2.0L, Kelford 272 cams, JMF SMIM, FIC 2150s, Precision 6765, ECMlink V3.
E85 32psi - 649FWHP, 444FWTQ. (ran out of injector).
I FIX AND TUNE (DSMlink & ECMlink) 4G63'S PM ME FOR DETAILS.
P.S. Its good to see you on dsmlink forums.
guess im the only one that thinks a Bent hbeam is sexy can i have it?at least the wixecos held up that says alot!!! call Eagle you might get a free replacment tell them man DEFECT
i love AUTOZONE
i love AUTOZONE
Jerry you do understand slightly the wastespark ignition systems that the cars come with from the factory but I hold your statement to not make any logical sense of the destruction of your motor or karims motor. The wastespark fires at BDC which is correct but when the plug lights off, the exhaust valves are open, this wont create any "load" on the pistons/rods, this wont create any kind of "compressive force" because simply with the exhaust valves being open, there isnt any compression in that cylinder. Unless your stock ignition system works different then mine does, im sure you will rethink your explanation.
my favorite quote
my favorite quote
Sorry I didnt explain it clearly. wasted spark doesnt happen at BDC. It happens at TDC at the end of exhaust stroke. its not burn gasses being expelled but an ignitable mixture since there was a mis fire (no fire) . The exhaust stroke doesnt empty cylinder completely and at top of exhaust stroke there is enough fuel/air to be ignited. as piston goes down on intake stroke more ignitable gas/air enters chamber. but it enters into a chamber that is burning. The piston is traveling down bore on intake stroke but the mixture entering chamber is burning at same time. there is no exhaust valve open this round when the piston is traveling back up bore. it is now compression stroke time. the hot expanded gases are very hard to compress. the piston end pushes rod down on its end and crank is pushing up from other side . rod is very easy to bend like this. pre ignition is far more damaging then detonation. it happens much quicker and is harder to detect because there will be no knock noise. detonation happens when pistons are at or very near TDC. the crank pin is not in a position to be rotated so the compression usually lifts head and blows gasket. when that happens there is no real stress on the rod. it is in its strongest position and the lifting head releases the excessive compression. pistons get hurt and rod bearing get beat on but rods survive just fine. hope that clears it up a little better for you.
P.S. Jerry how do you like that dsmlink so far? Im assuming your running V3? Going mitsu maf, gm maf-t or SD?
yes this was on e85. I was there to hear the misfires. e85 is far more likely to pre-ignite. dont have time to right a 2000 word essay on the hows and whys. is is suffice to say bent rods are common on alky and misfires. this is exactly why I never ran stutter launch on yellow car. 93 with meth injection is bad news under this condition. some guys in canada kept bending rods on the stutter box with their meth injected cars. if you hit 9psi on the line on the stutter and your meth is turning on at 5 psi you have a perfect condition for pre-ignition.
my favorite quote
my favorite quote
