2g Dsm Ecu Flash
2g Dsm Ecu Flash
Anybody have information on 2g 97-99 ecu flashes? Just wondering how well it works. I understand its new this year and want to know information on how well it works and if its a positive mod.also is there a way to remove 6bolt random misfire while flashing? please give feed back on expierence or opinions thank you
why dont you go to www.dsmtuners.com and do a search for this this a huge thread on it
I havent done it yet but been watching the thread. You need a black case 98-99 ecu. ten times better than afc tune. I was considering this for blue car then ended up buying a dsm link. the tune being the most important part of your car it doesnt make much sense to skimp a few hundred in that area. the link is well worth the extra
my favorite quote
my favorite quote
yes and true
my favorite quote
my favorite quote
Yes. Download ECUflash and play around with a stock ROM. You can adjust the afr over different amounts of load, as well as the timing advance. No more tricking the car by screwing with the airflow signal.
if it turns out anything like the evo 8 ecu, you will eventually be able to have boost by gear, no lift to shift/2step etc.
I got an evo ecu for my car but the obd2 port is fucked so I cant disable the immobilizer *doh*
Yeah man thats the 2nd time i ran into a sti while my car was fukd up lol.. I put on a aftermarket 02housing and my dumbass buddy over tightened the turbo bolt to manifold and snapped it off into the turbo. so i had no boost along with a huge exhaust leak. but everything is fine now. tapped out the bolt and installed arp bolts back running strong hopefully i can run into another subie on the expressway lol. but anyway back on topic. im going to try the tune with the flash and see how it goes.
