stock or not stock
Old Sep 9, 2009 | 05:58 PM
DANNYTURBO's Avatar
Default stock or not stock
the other day by mistake i over turned my manual boost controler. My talon over boosted to 30psi and did not brake on premium gas 91 octane... My tuner tells me that it may have after market pistons and rods.. How can i find out other then taking the head of the block....
93 talon fwd
Old Sep 9, 2009 | 06:26 PM
ryu's Avatar
ryu
JUDGE RACING
Remove the oil pan.
Stock turbo/Stock Block- 10.80@125.97mph
FP Red/Stock Block- 10.301@132.93mph
http://www.youtube.com/watch?v=k2CqirgpFeM
Hta3582 w-.63Tial/Stock Block- 9.96@139.83mph
http://www.youtube.com/watch?v=rxjaKUnUZNk
Tampa's Quickest Mitsubishi
JUDGE RACING
Join us on Facebook
http://www.facebook.com/#!/pages/Judge-Racing/203463879689026
Sponsored by:
MAPerformance
Old Sep 9, 2009 | 06:29 PM
concordcobra's Avatar
Breakin tranny's
How bad did you overboost, What PSI do you normally run? How long was the pull? How many times did you do a 30psi pull?
Old Sep 9, 2009 | 06:40 PM
JR.'s Avatar
JR.
stock or aftermarket u should be able to make upto 500-550whp, so dont worrie about it to much... crank the boost with higher oct fuel and a good tune.
98 talon awd automagic
Old Sep 9, 2009 | 06:43 PM
cyloc's Avatar
TR Shop Mod
other way to check is to use a borascope. You can go in the oil pan plug hole and in the spark plug holes
JUDGE RACING
Old Sep 9, 2009 | 11:31 PM
LS1Fever's Avatar
Easiest way right here.
Just because you overboosted once and it didnt blow, it doesnt mean right off the bat you have pistons/rods. Anything can blow up when something like that happens, even with aftermarket rods/pistons. Just be careful that it doesnt happen too often. You may have just gotten lucky.
Old Sep 10, 2009 | 05:29 AM
lancerman's Avatar
I would put my money on stock parts. no one sells a car without informing new owner the engine has built internals. stock engines can handle momentary over boost. and forged internals only buy a few seconds of safety when detonation occurs.
my favorite quote
Old Sep 10, 2009 | 02:31 PM
DANNYTURBO's Avatar
thanx alot u guys are alot off help wiil let u know soon. After it gets tuned the right way how much hp i made and dyno sheet if am about to post it
