95 3000gt sl overheating smoking and squealing
fast car nascar w00t
on
This week i noticed my car was making a bubbling sound randomly. My temp was normal and there was no excess heat comming from my car. a couple days later it was happening again then i heard a like snap and it started squealing and the temperature started to increase. almost into the red. turned the engine off and I got out of the car and antifreeze was leaking out of the bottom. I waited a couple hours before restarting to let cool. I put water into it and started it up.. no squealing for the first few min. after about 3 min it started to squeal and begin to smell hot. i checked the thermo gadge and it was still below the cool level the fan had not kicked on and it was starting to smoke. i checked my timing belt to see if that could be the problem but its still in good shape and on correctly. the smoke appears to be comming from the right side of my over head cams. near the timing belt... any ideas?
water pump,the inside turbine.
When you think you know everything there is to know,thats when you start to learn.
Chip Foose
http://www.teamrip.com/
http://www.importperformanceparts.net/
Chip Foose
