installing guages
Old Jul 23, 2009 | 12:24 PM
Needfstwheelz's Avatar
^ HIGH...My Name Is
Default installing guages
so i just picked up pro comp ultra lite vac/boost and oil pressure guages.
plain looking i kno...i dont really kno how to setup the oil pressure guage. do i have to get the cluster out to disconnect both stock guages???
how have you guys done this install?? as simple as it may be....
97 Mitsubishi Eclipse GST
95 Honda Civic ex coupe
95 Eagle Talon ESI
92 Mitsubishi Eclipse GSX
90 Acura Integra LS
94 Honda Civic ex coupe
90 Honda Civic std hatch
90 Acura integra LS
91 Acura Integra GS
98 Acura Integra RS
90 Acura Integra LS
93 Acura Integra RS
91 Acura Integra LS
90 Acura Integra LS
92 Acura Integra Gs-R
Old Jul 23, 2009 | 12:35 PM
omgosh's Avatar
What type of oil pressure gauge is it? Mechanical? Or electric...
If its mechanical it needs a line run to an oil pressure source...and if its electric it needs to be hooked up to an oil pressure sender (don't know if you can use the factory signal, but if you can I'd just tap into the wire behind the gauge cluster...) I doubt the factory sender is that accurate though, its more of an "oh shit the gauge is pegged at the bottom" warning than an accurate measurement from what I understand..
The boost gauge is most likely mechanical as well... so you need to run that clear vacuum hose to a boost source, ie charge pipe/intake mani nipple.
Old Jul 23, 2009 | 12:39 PM
^ HIGH...My Name Is
mechanical
95 Eagle Talon ESI
90 Acura Integra LS
90 Acura integra LS
91 Acura Integra GS
98 Acura Integra RS
90 Acura Integra LS
93 Acura Integra RS
91 Acura Integra LS
90 Acura Integra LS
Old Jul 23, 2009 | 02:42 PM
omgosh's Avatar
Time to run some lines then. I used the steering column boot on the firewall for the boost gauge, I don't know what you wanna do for the oil line, might wanna wait for someone else to chime in.
Old Jul 23, 2009 | 02:56 PM
xxsupralvrxx's Avatar
www.dsmtuners.com , www.dsmtalk.com , and www.Vfaq.com are your freinds lol
Old Jul 23, 2009 | 07:52 PM
wishiwasfast's Avatar
Run it off the 'P' line on the throttle body.
Old Jul 24, 2009 | 08:13 PM
TURBOLAG48's Avatar
P off the throttle body is fine.. there is one better... but i really cant remember... either way do not forget about VFAQ Site - Visual Frequently Answered Questions is the best DSM source I have found... no q/a just straight tech talk.. if you cant find your way around there you dont belong around a... (just kidding) I never saw that movie....
Old Jul 24, 2009 | 09:16 PM
Tom N's Avatar
Non DSM.....DSM guy
You do not want a mechanical oil pressure gauge inside the car.
Tom
Old Jul 24, 2009 | 10:10 PM
^ HIGH...My Name Is
and why is that??
95 Eagle Talon ESI
90 Acura Integra LS
90 Acura integra LS
91 Acura Integra GS
98 Acura Integra RS
90 Acura Integra LS
93 Acura Integra RS
91 Acura Integra LS
90 Acura Integra LS
Old Jul 25, 2009 | 05:09 AM
Tom N's Avatar
Non DSM.....DSM guy
Originally Posted by Needfstwheelz
and why is that??
Because you have to run a oil line to the back of the gauge. And when it leaks it will leak oil into the cabin of car. Thats a fire hazard and its dangerous.
Tom
