blue car gets drunk
moonshine babay!
just got back from first drive on e85
my favorite quote
my favorite quote
The fuel upgrades. out with the 780s. in with the bosch 1000s. these injectors are nuts. you can run 90psi base and 45psi boost and get 1500cc flow. decided against dual pump setup. sticking with my reliable supra pump with kenne bell boost a pump. I like that it regulates pump voltage to 17.5 volts even if battery voltage drops to 11volts. And it does this under boost only. I am looking for a table top a/f graph on this car. stock fuel regulator crushed to hold 50-55psi base. havent heard of anyone doing this but why not? popular to cruch dsm and evo9 bov why not the fuel regulator?
my favorite quote
my favorite quote
Same goals 400+ whp. Just want to get away from unreliable meth injection.
my favorite quote
my favorite quote
Interesting, remember that higher fuel pressure equals less fuel flow. On a high boosted car id keep the base fuel pressure as low as possible, only reason to jack up the fuel pressure is if you didnt have large enough injectors but have more then enough pump. Id check fuel pressure at redline to see if its dropping off at all then adjust the boost a pump as needed to maintain a steady psi. I also wouldnt boost reference the boost a pump off of a cheap hobbs switch, i think thats just asking it to break. I know the boost a pump was designed for variable voltage returnless pumps so it will be interesting to see how a return style pump likes it.
in memory of Kevin Gonzalez 6/21/86 - 9/13/06
