Eclipse camshaft? Help!
Ok An Eclipse comes stock with DOHC Dual over head cams correct? well if they dont My friend has DOHC under the hood of his Eclipse Now in that are the cam shaft that are above the pistons that contract up and down Orcastrating the Process of Intake and exhaust But above the pistons are the 2 or 4 little Rods that contract up and down with the pistons what are they? Are they the valves? if not where are the valves? please help me.
what the fuck are you talking about???? go read a fucking book or something......One other thing the little lever that says hood open never touch it again!!!
eric
eric
eric.
Build your car for YOU, not for the fame and glory. Fame and glory fade with time but YOU will be around as long as you live.
eric.
yo chill the fuck out Im a newbie to this... i mean This is mitsubishi tech well be techish i want help..I want to know more about V 6 and blah blah So please help me out with my questions..
Originally posted by "Someone"
eric
eric
It sounds like you are a little over your head. What is the reason for asking this question? It sounds like you are talking about valves.
Ok the valve is the whole thing surrounding the piston I understand now How the engine works..but tell me if i got this right..Please its important to me to know this..19 years old and i dont know crap..ok here goes
I dont understand turning the battery but Intake comes in air enters where the piston is combines with the gas and the spark plug ignites a small charge of sorts and the piston contracts down then back up the intake lobe closes then it goe back down then the exhaust Lobe opens and lets out the Exhaust the Exhaust then leaves through the Headers then goes down and out of the Exhaust Pipe??
Seriously if you want to learn all of this you have been given webistes to look at. Go to Barnes and Noble or to Books-A-Million and buy a Idiots guide to engines or something. You are going to get on everyones nerves (and apparently already are) by going into all the forums and asking the same questions about how engines work. Find a friend to talk to in person or something. Do a little research all this stuff isnt too hard to figure out. But youre like a computer spaz posting all over the place about this.
Edit:
If you want to learn about DSMs (Mitusbishi/Eage) go to Http://www.vfaq.com
Edit:
Sorry i just wanted my questions answer.. I can only understand what i read to an extent and from then I need someone to explain...
But its all good now i know all that I need to know..
