holset rebuild
how hard is to rebuild a hx35 holset turbo? i got it off of the computer, it spins freely, and seems fine. i just want that little bit added security knowing the turbo is good (new) when i get done fixing my motor. the reason i'm asking is because my local shop wants to much to do it..
What do they want?
You can probably fine local diesel truck rebuilders to do it for less than 300 bucks, or even give the GoldFarb & associates guys a ring. If you get it rebuilt get the billet wheel.
I recently picked up a 56mm 6blade billet wheel Hx40 for 200bucks. It spins freely also and doesnt visually have any damage on the blades, nor any noticeable shaft play.
GL with your turbo.
GL with your turbo.
Officially Dsmless...
"America remains one nation, under drugs, indivisible, with perceived liberty and sickness for all." - Shane Ellison
not really any such thing as preventative maintainance on a turbo. you wont find a turbo shop that will freshen the turbo up for less than 275. kinda defeats the purpose of buying a cheap turbo then rebuilding it before you use it. if blades dont hit housings the turbo is likely good. dont fix it if it aint broke.
my favorite quote
my favorite quote
+1
+1
Moved to Pa
Moved to Pa
