HID Question
Old Mar 4, 2009 | 03:04 PM
Slo_RydP5's Avatar
Ryce Hater
Default HID Question
this may seem like a newb question, but when installing HID's on a DSM (2nd Gen), is there anything special i need to do to get them to work?
i installed a brand new set of HID's tonight (plug and play) simple install took me about 30mins, when i turned the lights on the lows (9006) don't work at all. i thought i may have blew a fews so i put the old bulb back in and it worked fine, the turn signal works, the high beam works, but the 9006 HID will not work for some reason.
nothing is wired wrong,cuzz like i said its a simple plug and play set-up so you really can't screw something up, i just wanted to check to see if there was something that i need to do for the lights to work on a DSM.
if it matters the HID's are a 55w 10k bulb/ballast
Old Mar 4, 2009 | 03:10 PM
chillllll's Avatar
11 second club
I had to splice the wires on mine...sometimes they don't work when you just plug it in, but sometimes they do
10 sec street truck...
Old Mar 4, 2009 | 03:23 PM
Slo_RydP5's Avatar
Ryce Hater
problem solved, apparently there is a polarity issue when you hook up the wire running from the bulb to the ballast....you have to basically turn the wire around and hook it up "backwards"
see step 6-8 for details of what i mean
http://www.sharphid.com/installation/2gdsminstall.pdf
Old Mar 4, 2009 | 03:27 PM
Slo_RydP5's Avatar
Ryce Hater
maybe if you would of known what i just learned you would not of had to splice them?
sucks to have to splice a plug and play system....but atleast it works for you
Old Mar 4, 2009 | 05:16 PM
lorijuan1024's Avatar
Same happened with mine I got them from eBay $60
Old Mar 4, 2009 | 07:50 PM
Slo_RydP5's Avatar
Ryce Hater
did u get an EBAY brand HID or an actual known brand?.....did they come with any type of warranty?
Old Mar 4, 2009 | 09:24 PM
omgosh's Avatar
EDIT lol didnt read the thread.
I ran into this issue too. Fired the lights up and .. "noooo!" but after SEARCHing on tuners I found that info...lol.
Old Mar 5, 2009 | 12:06 AM
chillllll's Avatar
11 second club
I had to splice them because the wires were already spliced due to the aftermarket housings lol
Old Mar 5, 2009 | 10:23 AM
Slo_RydP5's Avatar
Ryce Hater
the aftermarket housing you refer to....is that something similar to the blacked out headlights with halo's that are sold on ebay???
or something different....you would think stuff like headlights and taillights would be plug and play if ur buying lights for a specific car
Old Mar 6, 2009 | 07:02 AM
No name brand just says hid outlet or sum but yea like 3 yr warranty
Mine didn't work so I called the eBay shop that sold it and the guy says the people that make them are idiots but plug them in backward LOL
