Question about 2g sunroofs
Old Feb 5, 2009 | 10:53 AM
Krais's Avatar
One less bolt than you
Default Question about 2g sunroofs
My 1996 eagle talon sunroof bracket is broken, I found a cheap 1996 ECLIPSE sunroof, the entire thing. Brackets, engine, and glass.
Back to my question, Will it bolt up with no issues?
Old Feb 5, 2009 | 04:27 PM
chillllll's Avatar
11 second club
it should
10 sec street truck...
Old Feb 5, 2009 | 04:49 PM
Krais's Avatar
Originally Posted by chillllll
it should
If it doesn't Whoopty do im out a tiny bit of cash. If so, I can sell it on here for the same amount if not more. Its that cheap.
Old Feb 9, 2009 | 07:24 PM
99_Clipse_GS's Avatar
eclipses/talons are the same thing. their parts can be used on either
whats this
Old Feb 11, 2009 | 05:31 AM
toyotiny's Avatar
if that one doesent work out let me know i have one to with everything!
THE WING MAN NEVER LETS YOU DOWN!
Old Feb 11, 2009 | 01:22 PM
Krais's Avatar
Will do. Do you know how to rip the engine out of mine so i can put the new one in? Ive already removed the glass, the brackets, But i can't remove the brackets, Because the cables are still connected to the engine of the sunroof.
Old Feb 12, 2009 | 04:29 AM
toyotiny's Avatar
never done it that i can say but iv been a tech for 10 years i have yet to come across a part i cant remove in one peace! well figure it out! ill take a look at mine and hit you back!
Old Feb 12, 2009 | 09:04 AM
Krais's Avatar
Alright cool, Thanks. the engine to the sunroof is right by the button to move it back and fourth, I take out the 2 screws, and you can pop the plastic piece off. But then theres almost nothing i can do.
Old Feb 21, 2009 | 05:28 AM
toyotiny's Avatar
sorry it took me a few i have been busy!i just took mine of your problem is theres three screws holding the motor not two! i took them all out and gave it a shake and it fell right out! just take a better look at and you will see the third screw! thay make a triangle shape!
Old Feb 21, 2009 | 05:31 AM
toyotiny's Avatar
oh ya and you dont remove the cables to remove the the hole thing! just the four drain lines! then the 6 trox srew on the glass and then the 8 10mm nuts holding the frame. dont forget the one by the front windshield its kind of hiden!
