boost leak test help
Old Jan 29, 2009 | 09:01 PM
dsmturbo84's Avatar
Default boost leak test help
is there anyone in ocala that can help me to see if i'm having boost leaks on my car??
Old Jan 29, 2009 | 09:24 PM
mikiemike75's Avatar
mikiemike75
what year car and whats all done... let me know.... pm me i can help out i have a leak down kit...
Built By:Mike Carpenter @ Overdose Performance in Ocala,Fl...
Tuned By: Tony Gannon @ Hp Performance
hp~5!! trq-4!!
doing work!!!!!!
Old Jan 30, 2009 | 04:53 AM
dsmturbo84's Avatar
i got a 96 spyder all stock all it has is a greddy blow off valve it has a 6 bolt in it has well
Old Feb 1, 2009 | 03:16 AM
dsmturbo84's Avatar
can anyone help
Old Feb 4, 2009 | 11:30 AM
Neesan's Avatar
EL RIPPO
Go to an ACE hardware. They have everything there for under $10 to build one. Go to the PVC pipe section. Youll see black rubber hoses about 6 inches long with 2 clamps on them, buy one that looks to be the right size (there arent too many different sizes, youll know which one is right) and buy a pvc cap that fits inside it. Then ask someone there where there valve stems are, they only have one kind, a brass type that will screw in. Drill the cap out and screw the valve in and clamp the cap into the hose. DONE.
< Forged internals with squirters stock. 14psi proof. It WILL be turbo'd, just not anytime soon.
Old Feb 4, 2009 | 12:57 PM
98_GstEclipse's Avatar
I need to do a boost leak test too. You'll need an air compressor too
