intake mani...HELP
Old Jan 13, 2009 | 06:01 AM
Needfstwheelz's Avatar
^ HIGH...My Name Is
Default intake mani...HELP
if something is wrong with my intake manifold will it make any wierd noises....im sure somebody has had a reason to swap thiers in the past....
97 Mitsubishi Eclipse GST
95 Honda Civic ex coupe
95 Eagle Talon ESI
92 Mitsubishi Eclipse GSX
90 Acura Integra LS
94 Honda Civic ex coupe
90 Honda Civic std hatch
90 Acura integra LS
91 Acura Integra GS
98 Acura Integra RS
90 Acura Integra LS
93 Acura Integra RS
91 Acura Integra LS
90 Acura Integra LS
92 Acura Integra Gs-R
Old Jan 13, 2009 | 09:21 AM
fallen4ng31's Avatar
Cogito ergo sum
Noises? The manifold itself has no moving parts. If there is a hole/crack in it, however that would probably cause some odd sounds. Intake manifolds usually don't "go bad."
"Kid, If you call me 'bro' one more time, I swear to Christ you're going to find out what your left testicle tastes like."
I offer professional computer / network services and consulting.
Over 10 years of industry experience.
A+/Network+/Security+ Certified ; CISCO CCNA, Novell CNA, Microsoft Certified IT Professional.
Old Jan 13, 2009 | 10:12 AM
^ HIGH...My Name Is
i think i might have a crack or gasket is possibly shot out...
95 Eagle Talon ESI
90 Acura Integra LS
90 Acura integra LS
91 Acura Integra GS
98 Acura Integra RS
90 Acura Integra LS
93 Acura Integra RS
91 Acura Integra LS
90 Acura Integra LS
Old Jan 13, 2009 | 10:18 AM
TurboedHondaB16a's Avatar
Thats what she said
on my civic one time the gasket on it was bad and it made a squeling noise. Feel around it.
Old Jan 13, 2009 | 11:09 AM
blackFLgst's Avatar
Probably $#%#ing broke.
check the intake manifold gasket, throttle body and or vacuum lines that could have come disconnected
REDLEG
13F
2010 Evo X GSR
Mods: 11's
Old Jan 13, 2009 | 12:01 PM
Evil_GST's Avatar
Pure Evil
do you have a boost/vac gauge?? if so what is your vacuum at idle?
Old Jan 14, 2009 | 04:29 AM
toyotiny's Avatar
take a spray bottle like for windex or somthing of that nature put some water in it and spray the manifold,vacume hoses,mating surface,throttle body,idle screw and base were the injectors sit wile the car is running. trust me you will know if you hit a spot thats leaking.this can also be done with carb/choke cleaner just be carfull were you spray it! iv seen guys go a littil crazy this way and start a fire!
THE WING MAN NEVER LETS YOU DOWN!
Old Jan 14, 2009 | 04:33 AM
^ HIGH...My Name Is
im sure somethings up back there...i hear a hissing noise but its in a bad spot that i cant really get to.
95 Eagle Talon ESI
90 Acura Integra LS
90 Acura integra LS
91 Acura Integra GS
98 Acura Integra RS
90 Acura Integra LS
93 Acura Integra RS
91 Acura Integra LS
90 Acura Integra LS
