need help
Old Jan 2, 2009 | 05:00 PM
jst4shw's Avatar
Default need help
i changed my clutch, t/o bearing and pressure plate because it was slipping and after i put it back together , the clutch was to deep before it goes in gear , i bled the line and it was still the same, i changed slave cylinder with a new one and it was still the same, then went to the junkyard and got a master cylinder and still no luck , dont know what to do but there is a damper in between master ans slave that i did not touch, need your help guys oh yeah , its a 98 eclipse gst and the clutch is exedy brand new
jst4shw Store: HID's-LED's-STICKER's-Tshirt's-JDM GOODIE's
TR shop
Like us on Facebook
text/call 813-407-3314
TR em1 crew #1
TR " eg6 " crew #1
Old Jan 2, 2009 | 05:33 PM
Tom N's Avatar
Non DSM.....DSM guy
what kind of car is always helpfull. What brand clutch and pressure plate. Were theyboth new and did you have the flywheel surfaced.
Old Jan 2, 2009 | 07:19 PM
slowy's Avatar
13.04@104mph
i'm going to have to ASSume its the 91gsx.
sounds like you needed to just adjust your pedal to get the correct engagement point
Old Jan 2, 2009 | 07:34 PM
Dario99gst's Avatar
Tu Papi Chulo
I'm with him/\/\/\
-Dario
DiSplaceMent Replacement
IF YOU NEED ANYTHING FROM CHASE PM ME!!
Old Jan 2, 2009 | 09:45 PM
jst4shw's Avatar
how do you adjust the pedal ?, i dont see no adjustment on the pedal
TR shop
Like us on Facebook
TR em1 crew #1
TR " eg6 " crew #1
Old Jan 2, 2009 | 09:47 PM
jst4shw's Avatar
and the flywheel was not resurfaced ,look good when i pulled the old clutch out
TR shop
Like us on Facebook
TR em1 crew #1
TR " eg6 " crew #1
Old Jan 2, 2009 | 10:10 PM
DarksideZ's Avatar
TR Balla Donor Supreme
This should help you get started
Clutch Adjustment
Old Jan 3, 2009 | 06:35 AM
slowy's Avatar
13.04@104mph
this pic shows it all. it'll take a few tries to get it exactly where you want it
you basically loosen the nut that is on the bolt that connects the MC to the pedal, turn the bolt to move the engagement point in/out and re-tighten the nut
