Electrical Problems
Old Oct 30, 2008 | 07:37 PM
Skyline Driver 5's Avatar
round and round it go
Default Electrical Problems
Ok so i accidentally grounded out my alternator and alot of things dont work anymore. For starters my windows and power doors dont work anymore. i replaced the alternator, belt, battery and the alternator fuse that blew. now im smoking from under the dash close to the fuse box. all my fuses are fine and the car runs fine but it dies after driving for an hour. and when i drive at night my coolant light and e-brake light luminates half way then goes off then come back again. anyone have this problem accidentally grounding out their alternator?
TR "Old Skool EF" Member #150
Old Oct 30, 2008 | 07:56 PM
Evil_GST's Avatar
Pure Evil
Grounding the alternator always blows the 80amp alternator fuse from my experience. did the alternator fuse blow a second time after you replaced it? Also I have had the alternator fuse burn up near the bottom where it was not visible through the glass, when you check them make sure you actually take the glass of and inspect it. other electrical issues im not sure, the fuse is supposed to protect against other problems. are you using the correct fuse?? if not that could explain the smoke under the dash.
Old Oct 30, 2008 | 08:45 PM
GsEclipse02's Avatar
i dont think u should have a gst ... you always have problems
Old Oct 30, 2008 | 08:50 PM
xCLoVeRxG's Avatar
vtakkin
if a DSM throws crazy dashlights, it usually indicates a bad alternator. when mine went out it threw the coolant/battery light. and yah check all the fuses, and make sure you replaced the fuses with the right amperage, if there too small they will burn up again.
Old Oct 30, 2008 | 09:42 PM
THE_ONE's Avatar
*Turbo Interceptor*
Old Oct 31, 2008 | 09:42 AM
lol i love my gst and im not getting rid of it unless i get an evo. i replaced the alternator fuse with the right one and i put a new alternator. i just dont understand why my fuse box in the cabin was smoking and smelled like burnt wires and my windows and door locks wont work. i completeley took out the wiring harness under the dash and i dont see any visible damage to the wires, just the little box attached to the fuse box had burnt up
Old Nov 10, 2008 | 11:01 AM
cody_ettl13's Avatar
YEAH I KILL IT
kevin had this problem its the alternator ask him all we did tho is replace his alternator.
<RIP-TIM>
Old Nov 10, 2008 | 04:31 PM
Neesan's Avatar
EL RIPPO
Ill trade you my 1G AWD. I saw your car at damons today, its a mess.
< Forged internals with squirters stock. 14psi proof. It WILL be turbo'd, just not anytime soon.
Old Nov 10, 2008 | 04:38 PM
well it probably wouldnt be if he started working on it. the dash is out thats why it looks so bad. all he needs to do is swap the engine harness and fusebox. ill think about it and get back to you if he doesnt get the ball rolling
Old Nov 10, 2008 | 05:34 PM
dipstyc1928's Avatar
16g
i have the same problem. i think the short for the windows is in the switches. me and damon screwed with mine but didn't finish. my stuff somewhat works. ask him to try some other swithes if he's got some lying around.
THE PRICE IS WRONG BITCH!!!
